| Home > Help Needed / General Tech Chat > fitting 1300gt gearset into a later a+ box | |||||||
5th Jul, 2009 at 07:03:12pm
hi does anyyone know whats involved in this conversion?
5th Jul, 2009 at 07:06:54pm
I belive the MPI has a close ratio gearset,
5th Jul, 2009 at 09:55:30pm
GREAT MOD!! It's extremely easy as all the GT bits will fit straight into the A+ casing. On 13th Jul, 2012 Ben H said:
7th Jul, 2009 at 12:52:22am
what difference would be noticed with the cr gearset?
7th Jul, 2009 at 07:26:04am
The only real benefit is a stronger gearset.
I seriously doubt it! |
7th Jul, 2009 at 08:22:21am
as Paul stronger gearset,
On 7th Jul, 2009 paul wiginton said:
The only real benefit is a stronger gearset. Its not a straight swap though. The centre main web needs relieving to make clearance for putting in the main shaft. Paul |
7th Jul, 2009 at 08:42:47am
The only real benefit is a stronger gearset. Its not a straight swap though. The centre main web needs relieving to make clearance for putting in the main shaft. Paul Please elaborate? I've fitted several A gearsets in A+ boxes and have never relieved anything. The best with this conversion is not the stronger gears but the closer ratios. The A+ ratios are junk for a modified car, including forced induction ones. On 13th Jul, 2012 Ben H said:
7th Jul, 2009 at 09:40:45am
Ive had to relieve the case a few times to do it, I believe Fastcarl did too.
7th Jul, 2009 at 10:35:02am
Veg just read:
The only real benefit is a stronger gearset. Its not a straight swap though. The centre main web needs relieving to make clearance for putting in the main shaft. Paul Please elaborate? I've fitted several A gearsets in A+ boxes and have never relieved anything. The best with this conversion is not the stronger gears but the closer ratios. The A+ ratios are junk for a modified car, including forced induction ones. |
7th Jul, 2009 at 10:54:03pm
Ah, at the first motion shaft end.. Yes, possibly.
8th Jul, 2009 at 08:03:22pm
No vegard it isn't possible, it's for SURE.
Ah, at the first motion shaft end.. Yes, possibly. I've rebuilt some Mpi boxes, and none have been CR. I believe this is bollox. Imagine how tall 1st would be if this was the case. |
) are close ratio
