| Home > Help Needed / General Tech Chat > Another Ignition Map request | |||||||
12 Posts Member #: 2766 Member Banbury |
6th Jul, 2009 at 02:09:31pm
Hi, I'm looking for a MJLJ map to run a recently rebuilt engine, whilst I run it in. The boot is currently limited to 8psi although after it's run a couple of hundred miles it will be wound up to 14 psi and have the timing and fuelling set up.
2646 Posts Member #: 1246 Post Whore Lowestoft, Suffolk. |
7th Jul, 2009 at 11:44:52pm
Think IIRC 24 acoross the whole map is safe. Search for James fawset aka feebleuk, think he was collating maps on a website.
8th Jul, 2009 at 12:00:37am
yep 24 should be fine at 14psi assuming you have the trigger angle right.
