Home > Help Needed / General Tech Chat > help with megajolt and turbo, Didcot, Oxfordshire
mike998
Member #: 2069
Oxfordshire
Hi boys and girls.
I need some help setting up my megajolt.
I have it all plugged in but cant get it to run on the megajolt, its just running purly on the EDIS system.
does anyone have the cable needed to set it up on the computer that i could borrow or even better could someone spare some time to come help me?
Im also having some problems with the engine, this morning was awesome, i was running about 8psi and the dumpvalve was working and everything, then i drive home from work and its squeeling at me and not boosting more than 3 psi. then i take it for a spin later without touching anything and shes at 5 psi without the squeeling this time.
Im very confused!!
thanks
Mike
mike998
Member #: 2069
Oxfordshire
Oh and forgot to mention the dumpvalve was not dumping on the way home or later this evening.
sid
Member #: 6376
oxon
squeeling??
do you know what was squeeling? if not as you are getting no boost are your turbo bearings still ok?
to check this take off the air feed hose and (with the engine off) stick your fingers into the turbo and ''wiggle'' the shaft the turbine is on, you should get no noticible movement, i wonder if yours is moving and letting the turbine touch the casing giving the squeeling noise.
just a thought.,
p.s. i live between didcot and wallingford, what colour mini do you have, if i am working i usually am running round in a yellow 850 lol *tongue*
Edited by sid on 7th Jul, 2009.
mike998
Member #: 2069
Oxfordshire
Sid mine is a blue one, has a white front end though as i havnt painted it yet.
ill check the blades tomorrow.
I suspect it may also be the little valve in the plennum but this should have been blocked before i baught the engine.
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
I think you need a setup :)
AlexF
