| Home > Help Needed / General Tech Chat > Mpi oil pressure | |||||||
928 Posts Member #: 65 Post Whore South Yorkshire |
7th Jul, 2009 at 01:50:49pm
Noticed recently that the oil pressure on our mpi mini is slow to build when starting from cold. It's 2, maybe 3 seconds before the light goes out and the noticable engine clatter stops. It has (clean) 20/50 oil in it and a champion oil filter.
7th Jul, 2009 at 03:04:21pm
worning oil pump and bearings...
AlexF |
7th Jul, 2009 at 03:08:43pm
Whats the milage neil?? 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
7th Jul, 2009 at 03:15:00pm
63k |
7th Jul, 2009 at 03:16:44pm
Don't condem the engine without first checking that the plunger in the relief valve is not stuck. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
7th Jul, 2009 at 03:17:19pm
Not intergalactic mileage but plenty to be caused by the things Alex mentions above.
7th Jul, 2009 at 03:17:54pm
On 7th Jul, 2009 Paul S said: Fair point!
Don't condem the engine without first checking that the plunger in the relief valve is not stuck. If something is worth doing, it's worth doing half of. |
7th Jul, 2009 at 10:08:59pm
Change the oil switch, only a few quid. Or fit an oil pressure gauge.
7th Jul, 2009 at 10:57:25pm
My money is on the big ends, being a bit worn, you may have had oil starvation at somepoint. But exhaust all the easy routes first! 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
7th Jul, 2009 at 11:29:14pm
my stab is a worn oil pump.
