Home > General Chat > Turbo oil feed take off from filter housing
Mr Joshua
Member #: 1954
Luton Bedfordshire
Been doing a little searching but cant find the answer. Where on the filter housing to you drill and tap to fit the turbo oil feed pipe?
Edited by Mr Joshua on 8th Jul, 2009.
Own the day
Could use one of these?
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...em=400060499981
Mr Joshua
Member #: 1954
Luton Bedfordshire
Got a sandwich plate fitted for the oil temp sensor. was rather hoping I would not have to drill it more.
Own the day
I have one of the ones in the link above, they have 4 1/8 NPT holes in them.
I've got one of these they have 4 take offs on them. Look pretty good too.
turbominivanman
Member #: 1504
Westbury, Wiltshire
I Tig'd a 20 mm dia ali bar about an inch long to the top of the filter head then drilled a hole through this straight through into the filtered oil delivery chamber of the filter head.
Then tapped the hole to take the thread of a standard male/male adaptor from Merlin with a copper washer underneath.
Decided to weld the little bypass valve closed. This lives just down the throat of the filter head delivery port if you view down it. In standard operation, this bugger opens with high filter differential pressure to allow unfiltered oil into the block and I didnt want that happening on mine.
Lastly connected a hose with a female swivel onto the male adapter and joined this to the turbo. Originally used a banjo elbow from the oil filter head but changed this in light of advice on TM to a male/male adapter and copper washer.
Bob is your mothers brother, as they say.
Richard.
