Home > Wanted > turbo shaft and compressor wheel
pete_mini
Member #: 5483
Exeter
Hi there guys, im after the turbo shaft and i think its called the compressor wheel, but may be the turbine. As im pretty useless at explaining, below are pictures of the parts that i need. If you have one or both that will be superb. many thanks. Pete
For what turbo?
pete_mini
Member #: 5483
Exeter
ah, yes that might help, sorry its off a standard metro t3
It's the turbo shaft and combined turbine wheel in the top photo, and compressor wheel in the bottom.
But what happened, looks like the shaft is bent as well as the compressor wheel damaged, ie, are any of the other bits damaged as well.
It might be worth just tracking down a second hand complete unit.
pete_mini
Member #: 5483
Exeter
iv been through all of it and the rest is undamaged, iv replaced all the other bits and pieces in the rebuild kit, and just need these bits to put it all back together. I have another unit but was hoping i could keep cost down if someone just had those bits
Star Mag
Member #: 375
Leicestershire
I have both of these. I can take to avon if you are going.
pete_mini
Member #: 5483
Exeter
bump on this thread, still not been able to source these parts. can anyone offer me just the above bits?
