Home > Help Needed / General Tech Chat > help with megajolt wanted
holtmini
Member #: 6593
south manchester
hi all
help i have fitted a megajolt on my turbo mini but i cant get it to start it tries to but it wont pick up if i give it more throttle it just dies, i have double checked all the wiring but im really stuck now heeeeeelp please, cheers darren :(
DrX rides again......
timing.
have you checked it with a light? try adjusting the table one way or the other until it runs, then you can check it easier. basically the same as the old "swinging the dizzy" trick
Ben H
Member #: 184
Melton Mowbray, Pie Country
Have you tried starting it with the MJ disconnected and just running on the EDIS. This is the first thing to get working before you start trying to get the MJ going.
http://www.twin-turbo.co.uk
sounds retarded
Ben H
Member #: 184
Sounds very retarded to me!
