Home > General Chat > Rear tracking / camber
1380turbo
Member #: 1211
Working up the BHP ladder.
Anyone give me some good starting figures for the rear setup?
Was thinking of going 0.5 degree negative with 0.5 degrees toe-in?
turbominivanman
Member #: 1504
Westbury, Wiltshire
0.5 degrees negative camber and 3.2 mm toe in seems to work well for me (not sure what that mm figure equates to in degrees toe).
I take the camber to 1.5 degrees negative and use 1.6 mm toe out on the front.
Richard.
sid
Member #: 6376
oxon
i think the rear toe in is recomended at 0 for road cars and about 1/8 of a inch for track cars.
3.2mm toe in is standard on the rear but I run mine parallel and you can notice the difference in a straight line, though it becomes a little skittish and takes getting used to.
Paul
1380turbo
Member #: 1211
Thats great Paul thanks, i will use those figures as a starting point. Running the back parallel must make things interesting *oh well*
Prawn
Member #: 5232
basingstoke
I had a bent rear beam for a while, and it was running parallel/slightly toe out on both sides unevenly, it made the car terrifying to drive!
Rammie2000
Member #: 10190
belgium
see this is a old post but do not want to open a new one. was installing my suspension the other day and got up this morning to set the tracking. had a problem with the rear that on one side i could get 1.4 degrees of neg camber while the other side only whent to 0.5 tops. but reading this 0.5 should be enough for the rear then?
Yeah, you don't need much at all on the rear. You have to consider as well on standard suspension with no play just how much positive camber the rears have you need to cancel out before you get to 0 degrees lol.
First make sure your floor is perfectly flat, this will dramatically effect your readings
Rammie2000
Member #: 10190
belgium
i set a level on the subframe and added spacers under the wheels to get it level. but its good to read that its normal ( to have so less) i rememberd my old mans simca ralley 1000 having 2 degrees of camber (was rear wheel drive and only for track use)
