| Home > Help Needed / General Tech Chat > Moving pipes around and a dizzi question your thoughts. | |||||||
11th Jul, 2009 at 12:24:26pm
Having sat and stared at my block for a few minutes I have decided on a few alterations. The oil temp sensor that fits in the sandwich plate behind the filter housing move to the oil pressure switch location ant the turbo oil feed pipe move to the sandwich plate.
Own the day
11th Jul, 2009 at 11:09:41pm
Under positive boost the vacuum advance is doing nothing..
Edited by Turbo Tel on 11th Jul, 2009. website:- http://www.terryhunt.co.uk
12th Jul, 2009 at 06:42:04am
i think you'll find that having the oil temp sensor at the pressure line will not give a correct reading as there is no flow there. It never seemed to work on mine. Best place is in the sump. |
12th Jul, 2009 at 10:23:40am
good point Own the day
