| Home > Help Needed / General Tech Chat > Dump Value / Big Intercooler | |||||||
621 Posts Member #: 393 Post Whore Oulton Park |
20th Nov, 2004 at 10:59:13am
969 Posts Member #: 47 Post Whore Not very sunny swanage |
20th Nov, 2004 at 11:05:06am
with big intercoolers, i belive you have more lag and a bigger potential for ppressure drop. have a search on intercoolers and have a read of anything written by turbodave, he seems to be the authority on this (and quite a few other) subjects....
And on the 7th day........... God created turbochargers! |
591 Posts Member #: 360 Stu from Corwall aka Mr Jazz Piano, Love_Machine, kneegrow |
20th Nov, 2004 at 04:00:43pm
I'm not an authority on Turbo Minis but I know a bit about heat exchangers.
Bugger off, I'm getting there. |
20th Nov, 2004 at 04:11:07pm
So, you buy a dump valVe becasue of the sound?? How childish is this?? Bou one that performs. On 13th Jul, 2012 Ben H said:
![]() 4641 Posts Member #: 20 My sister is so fit I won't show anyone her picture Lake District |
20th Nov, 2004 at 06:08:42pm
I would avoid the Bailey piston type dump valve, i've heard quite a few reports of the piston sticking due to fuel contamination.
Edited by Turbo Phil on 20th Nov, 2004. |
20th Nov, 2004 at 08:10:24pm
Thanks Lads smooth phil |
21st Nov, 2004 at 12:31:31am
or you can have itso it fits behind the grille and still allows a 'pikeyfree' internal bonnet release.
35 Posts Member #: 397 Member |
21st Nov, 2004 at 08:48:05am
turbo Dave - by the looks of you picture you are still using the original mini bonnet hinges. Does this mean you bonnet is flush with the bulkhead panel and not kicked up to let the hot air from the turbo out?
169 Posts Member #: 409 Advanced Member Bristol |
21st Nov, 2004 at 09:19:06am
My brother used to run a bailey dump valve, and it used to stick - never a good look! I run a kevlar diaphragm one, with no problems at all. Its also damn loud, and lets be honest Mr.Vegard, nothing wrong with a bit of posing, if you got it, flaunt it!!
Hannibal: There are two ways we can do this: the easy way and the hard way. In a few minutes my friends and I are going to come down on you like your worst nightmare. You're gonna wish the Earth had opened up and swallowed you whole.
21st Nov, 2004 at 10:36:53am
Dave - correct my bonnet is as originally fitted when my mini came off the production line - with the exception of the ERA vent on the back!
21st Nov, 2004 at 04:45:11pm
Thanks for that turbo Dae - I know i'm hi jacking someone elses's thread but is absolutley neccesary to kick the bonnet up or have an ERA vent, as I prefer the clean lines of a standard bonnet? Is there any way to get round this or maybe a compromise in between.
21st Nov, 2004 at 11:51:10pm
You can just drill large holes in the rear of the bonnet and not fit any vent or lift the rear of the bonnet... On 17th Nov, 2014 Tom Fenton said:
![]() 826 Posts Member #: 247 Post Whore Kent/Surrey Borders |
22nd Nov, 2004 at 12:07:43am
HA
Edited by b12 on 22nd Nov, 2004. TurboLessTosser |
22nd Nov, 2004 at 12:08:51pm
Turbo Dave - large as in what size? anyone else done this? thanks Dave |
22nd Nov, 2004 at 12:30:11pm
well under my ERA vent i have two 40mm diameter holes.
22nd Nov, 2004 at 01:34:47pm
On 21/11/2004 23:51:10 TurboDave said:
You can just drill large holes in the rear of the bonnet and not fit any vent or lift the rear of the bonnet... i grafted the vents from the back of the metro turbo bonnet into mine, looks factory Crystal Sound Audio said:
22nd Nov, 2004 at 01:52:49pm
have you got any pictures of thar wolfie? |
291 Posts Member #: 48 Senior Member Leicester |
22nd Nov, 2004 at 03:37:40pm
I'm planning on a similar thing to what Wolfie has done |
22nd Nov, 2004 at 08:24:20pm
if any ones interested halfords sell era type vents need to be ordered though 20 quid when i got mine no longer a series, but still 1.3 turbo.
