| Home > Help Needed / General Tech Chat > Homemade Flow Bench | |||||||
![]() 1547 Posts Member #: 2727 Post Whore Bicester |
17th Jul, 2009 at 09:12:51pm
I've been following David Vizards homemade flow bench guide and was planning on using a homemade manometer, but i was thinking would it be possible to use a standard production airflow meter ?(i have subaru one kicking around). wire up a power supply and connect a multimeter for the read out, then calibrate it by measuring the pressure drop. would it be sensitive enough? Any input would be gladly recieved. 1972 998 TURBO SLEEPER |
17th Jul, 2009 at 09:23:28pm
I suspect it'd be easier to use a 'flapper type' airflow meter than a 'hot wire' type... On 17th Nov, 2014 Tom Fenton said:
17th Jul, 2009 at 09:33:20pm
both give a 0-5v output w.r.t flow. as for sensitive enough, no idea, but if you find its not sensitive enough, reduce the orifice size or fit an air flow meter from a smaller engine car :) even then no idea if it would be sensitive enough. turbo 16v k-series 11.9@118.9 :)
17th Jul, 2009 at 09:36:47pm
Cheers guys, ill give it ago and keep you updated. 1972 998 TURBO SLEEPER |
17th Jul, 2009 at 09:52:04pm
thing is though, given you can make a manometer with some clear tube and a bit of wood, why reinvent the wheel? turbo 16v k-series 11.9@118.9 :)
17th Jul, 2009 at 09:58:24pm
good point, i was just thinking that if i can get good sensitivity i could get a more accurate result. 1972 998 TURBO SLEEPER |
18th Jul, 2009 at 08:58:51am
good idea chris ,,nicely lateral Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
18th Jul, 2009 at 09:35:28am
to be honest robert i got the idea from your flow bench setup 1972 998 TURBO SLEEPER |
976 Posts Member #: 3228 Post Whore North of the Netherlands |
18th Jul, 2009 at 09:58:38am
Nice idea.
Edited by Yo-Han on 18th Jul, 2009. Dazed and Confused.... |
18th Jul, 2009 at 09:59:46am
yeah thats the one ive been following, amazingly simple. 1972 998 TURBO SLEEPER |
18th Jul, 2009 at 10:00:25am
The man is a legend! Dazed and Confused.... |
1st Jan, 2011 at 10:33:28pm
found this,
