| Home > Help Needed / General Tech Chat > 998 Turbo fueling problem | |||||||
![]() 4 Posts Member #: 6441 Junior Member Bangor Northern Ireland |
19th Jul, 2009 at 04:01:58pm
Hi Ive just built a turbo 998 mini. Got it running however!!
19th Jul, 2009 at 04:07:37pm
Sounds like you've got too much fuel getting to your carb.
19th Jul, 2009 at 04:18:57pm
The regulator is fully open and i use 8mm pipe and ive even tried taking the pipe from the regulator return and putting it into a bucket so its only a foot long |
19th Jul, 2009 at 05:38:15pm
Having the regulator fully open will give you way too much fuel preasure! You need ot get a preasure gauge and set it correctly. Have a look in the How To section, there's a guide in there somewhere. On 11th Feb, 2015 robert said:
19th Jul, 2009 at 07:02:59pm
Have you checked the needle valve in the carb. Even 3psi will pass a knackered one. http://www.twin-turbo.co.uk
19th Jul, 2009 at 07:32:42pm
Two obvious things to check then.
19th Jul, 2009 at 08:56:06pm
Yeah its a metro turbo carb. Will maybe take a look at the needle valve. Anyone know if these are the same as an N/A carb as i have a spare one sitting. |
19th Jul, 2009 at 09:02:03pm
is the regulator a metro turbo one or an aftermarket one for a fuel injection car? turbo 16v k-series 11.9@118.9 :)
19th Jul, 2009 at 09:06:04pm
its a regular metro turbo one |
19th Jul, 2009 at 09:17:39pm
You seem to have all the rights bits then. If you could measure the fuel pressure at the carb, then you'd know if it was the needle valve or reg.
20th Jul, 2009 at 09:55:56am
Hd this happe nt o mine check the needle valve. Mine had some small gel like deposites on it From the residual ful that had been sat in it from the previous year. Own the day
