| Home > Help Needed / General Tech Chat > Electronic boost controllers?? | |||||||
96 Posts Member #: 251 Advanced Member Nottingham UK |
21st Nov, 2004 at 11:30:21pm
Hi guys, has anyone fitted an electronic boost controller. Can it be done to a mini without having an ECU and is there any major advantage over a bleed valve setup? |
22nd Nov, 2004 at 11:57:08am
It can be done, i toyed with the idea some time ago when i found some good jap equipment going cheap on ebay. I talked to the seller and from what he said it was entirely posible (but was he just trying to sell it to me?) But i couldnt be bothered with the hassle to be perfectly honest.
22nd Nov, 2004 at 10:34:21pm
What do they actually do, are they just a flashy regulator that allows you to bleed off variable amounts of boost to the actuator? |
23rd Nov, 2004 at 09:55:30pm
yea basically |
19 Posts Member #: 150 Member |
25th Nov, 2004 at 05:51:32am
Real high end electronic boost controllers are only really good for drag racing. They just allow you progressivly control the boost from start to finish so you dont have to leave the line under full boost and just kill the tires, but you will be under full boost by half to 3/4 track.
-james |
9 Posts Member #: 416 Junior Member Tiel, the Netherlands |
28th Nov, 2004 at 03:12:31pm
I'm hoping to fit this litle gadget:
Hugo
421 Posts Member #: 245 Senior Member |
28th Nov, 2004 at 09:50:48pm
my car is running electronic boost with the ecu
