| Home > Help Needed / General Tech Chat > AFR Gauge wiring | |||||||
![]() 536 Posts Member #: 5449 Post Whore Melton Mowbray |
20th Jul, 2009 at 08:25:29pm
cool, i'll pop over with my tool and some lube, lol 1293 88.8hp 82.2ftlb 17.3 1/4 @ 78 mph Naturally Aspirated (for now) |
20th Jul, 2009 at 08:55:46pm
wired to an ignition live, but it draws a fair enough bit of power to warrant its own relay :) turbo 16v k-series 11.9@118.9 :)
20th Jul, 2009 at 09:00:47pm
Is this wideband or narrowband ???
20th Jul, 2009 at 09:04:11pm
reading that I'm guessing its narrow band. What will the difference be between wideband and narrowband?
20th Jul, 2009 at 09:07:46pm
this is the one, this is off the autometer website
20th Jul, 2009 at 09:08:49pm
im assuming narrowband in my answer lol .. narrowband can only measure stoic, lean or rich, wideband tells you the actual AFR. but i did tune my NA motor with a narrowband and it worked well enough not to destroy the engine. but when compared to the wideband the fueling really was all over the place :) however, better than nothing! Edited by evolotion on 20th Jul, 2009. turbo 16v k-series 11.9@118.9 :)
20th Jul, 2009 at 09:15:25pm
Ive seen the gauges that give an actual AFR reading on them, so they are the wideband ones. Like you said, I suppose its better than nothing, and if I can tune it so its "safe", that will do me, because it will be going to the rolling road anyway to get it fine tuned, and also because I would like to know the power figure that it gives after all the hand work and money lol.
20th Jul, 2009 at 09:32:30pm
From the link, yes, narrowband, hence the simpler connections.
20th Jul, 2009 at 09:37:43pm
yes, I am currently building a turbo engine, so it might be worth the investment. I knew i should have looked into it before impulse buying >_< On 25th Sep, 2009 mini13 said:
20th Jul, 2009 at 10:45:48pm
if you got the likes of the innovate lc-1 or any wideband controller with programmable analogue outputs, you cn program the outputs to display the wideband output on your narrow band gauge turbo 16v k-series 11.9@118.9 :)
280 Posts Member #: 4340 Senior Member sideways, Birmingham |
22nd Jul, 2009 at 01:03:45pm
im running a narrowband afr, to be honest its a great improvement over not having it
On 15th Dec, 2009 fastcarl said:
sell the lot to me for £70 pounds and i'll let you stand on the outside edge and look on my inner circle of closest frinds, lol carl FOR EVERY WELL THOUGHT OUT AND WELL EXECUTED PRICISION JOB EVER CONCIEVED, YOU CAN GUARANTEE THAT SOMEWHERE IN WALSALL OR THE BLACK COUNTRY THERE WILL BE A BLOKE TRYING TO ACHIVE THE SAME BY MEANS OF "ITIN IT WI LUMP AMAR" |
but a proper wideband digital display is better as there is no issue with analogue voltage offsets affecting the reading.
for £25 it aint bad, but it does flicker a lot around stoich at idle, and drops of to lean for a few seconds when i push the throttle while cruising then jumps to rich? this could be my needle being weak though
