| Home > Help Needed / General Tech Chat > Recommended exhaust manifolds | |||||||
![]() 690 Posts Member #: 1851 Post Whore Woolavington, Zummerzet |
24th Jul, 2009 at 11:08:15am
Bit of a strange question (and I don't get on well with the search function) regarding exhaust manifolds, but I'm guessing that there will be someone here who can answer it.
Metric is for people who can't do fractions. |
24th Jul, 2009 at 11:20:14am
Are you intending to install two lambdas - you say takeoffs (plural) in your last sentence - in which case I've used the MG Metro cast manifold and standard downpipes and just welded the bosses on the mild steel part.
24th Jul, 2009 at 02:10:44pm
Your setup is along the lines of what I was thinking if the MPi setup isn't viable. The reason I put takeoffs plural is that the Rover manifold samples both halves at the same time to give an average reading. At the power/rpm levels I'm looking at, I don't think charge robbing will be a major problem. Metric is for people who can't do fractions. |
