| Home > General Chat > IGNITION TIMING AND MEGAJOLT | |||||||
80 Posts Member #: 4178 Advanced Member Chesterfield |
25th Jul, 2009 at 11:41:29am
Alright chaps, I am having some problems with excessive heat I can literally start the car and run it on tickover for 2-3 mins and the gauge is in the critical area, it's a little better whilst moving for obvious reasons but still very hot. I was wondering what the timing should be set at at idle. On the mj at present it is reading 15 degrees at 850 / 1000rpm I'm at little confused as the Haynes manual states 7-8 degrees at 1500rpm but people who I've spoken to have said higher ignition at idle and the engine runs cooler but be ware of detonation. Any help appreciated, lay mans terms would be better as i'm thick.
I am nobody, nobody's perfect. Therefore I am perfect |
25th Jul, 2009 at 11:51:14am
the 7-8 deg quoted in the manual is measured with the vacum pipe disconected so actual idle advance can be quite a bit more than this,
25th Jul, 2009 at 12:26:52pm
You are unlikely to get any detonation when the engine is not loaded, e.g. no throttle no boost, so don't worry too much about that at idle speed.
25th Jul, 2009 at 01:32:58pm
If your engine's standard, the 7 deg btdc setting should be ok. This is set at 1500rpm with the vac advance disconnected.
25th Jul, 2009 at 02:14:41pm
At idle the vacuum is round about 27psi blip the throttle and back off it will go to 30 so i reckon that is ok. I will have a look at the thermostat and maybe the gauge I am nobody, nobody's perfect. Therefore I am perfect |
25th Jul, 2009 at 02:25:07pm
27 psi?
On 25th Jul, 2009 roguesaga said:
At idle the vacuum is round about 27psi blip the throttle and back off it will go to 30 so i reckon that is ok. I will have a look at the thermostat and maybe the gauge On 28th Aug, 2011 Kean said:
25th Jul, 2009 at 02:34:25pm
that's what the gauge is reading, brand new equipment too I am nobody, nobody's perfect. Therefore I am perfect |
25th Jul, 2009 at 02:38:08pm
i thought it was high too, i have it teed into the old servo point on the inlet which also goes to the dump valve.
25th Jul, 2009 at 03:01:43pm
Are you sure it's reading psi and not "Hg (inches mercury).
25th Jul, 2009 at 03:04:02pm
i'll check and report back I am nobody, nobody's perfect. Therefore I am perfect |
25th Jul, 2009 at 03:07:34pm
I'm a pillock.. You are right it is in hg, 1 the vacuum half of the gauge is hg and the boost side is psi. I am nobody, nobody's perfect. Therefore I am perfect |
25th Jul, 2009 at 03:16:10pm
lol
25th Jul, 2009 at 03:22:43pm
lol. I was working on the the fact that i was told more vacuum on idle is better and seeing as my gauge was nearly off the scale i thought can't be that bad. as already stated i'm a pillock I am nobody, nobody's perfect. Therefore I am perfect |
