Home > For Sale > pre verto flywheel
andywaller
Member #: 1826
Maldon Essex
I've got for sale
billet ultralite flywheel
billet lightened backplate
6 drive straps
updated flywheel bolts
all from med
and also new minispares
release bearing
plunger
black powder coated leaver arm
looking for £230 posted
also found a new bolt and return spring i will chuck with it too
Edited by andywaller on 26th Jul, 2009.
andywaller
Member #: 1826
Maldon Essex
forgot this is all brand new and unused.
andywaller
Member #: 1826
Maldon Essex
is it all balanced etc andy?
andywaller
Member #: 1826
Maldon Essex
i belive so.
it was an med kit stage 2 kit or something so it came complete but I sold the plate and diaphram seperately as it was an orange.
yep just had a look and it has been balanced. just to add it's got pre engaged ring gear.
Edited by andywaller on 25th Jul, 2009.
too much wine, im having a mental block at the mo, is pre-engaged for the metro style starter or the old mini style with separate solenoid?
stefaz
Member #: 1656
stoke-on-trent
seperate joey :)
PaulH
Member #: 2340
Dublin Ireland
Nope pre ingaged is the metro style stater where the solenoid is a part of the starter. Inertia is the starter with the seprate solenoid :)
Edited by PaulH on 25th Jul, 2009.
On 17th Feb, 2009 Rob H said:
stefaz
Member #: 1656
stoke-on-trent
too much alcohols for me too not reading properly sorry. cheers for the correction paul
PaulH
Member #: 2340
Dublin Ireland
TBH stef its a horrible reflection on how sober I am on a saturday night :(
andywaller
Member #: 1826
Maldon Essex
I will put a photo up later.
i might have to bow out then, my race starter is for the older (inertia) type :(
Andy
I think this is right:
107 tooth is the inertia (old) style?
126 is pre-engaged (ala metro/A+)?
If you wouldnt mind counting them, if its got 107 teeth, Ill take it :)
andywaller
Member #: 1826
Maldon Essex
I got 129 I think I need a re count but it's definately not 107.
blast!
andywaller
Member #: 1826
Maldon Essex
I've got a pre engaged starter you can have for free with it!*tongue*
Simon
Member #: 1865
Norwich, Norfolk
YHPM
Text speak. You should be ashamed!
On 26th Aug, 2009 ZeroT said:
YHPM
1972-ANGUS
Member #: 3894
sallys gap. garden of Ireland
so its a pre verto flywheel, with pre engaged ring gear.
or a pre pre engaged flywheel, with post inertia ring gear
