| Home > Help Needed / General Tech Chat > PLEASE Help Me before i top myself! | |||||||
21 Posts Member #: 6195 Member |
27th Jul, 2009 at 04:20:07pm
hello,
27th Jul, 2009 at 04:30:48pm
The leads are available - icklemini makes them and sells on ebay I think.
27th Jul, 2009 at 06:28:01pm
If you have a turbo dizzy, you don;t need to get it adjusted to your engine for even a moderate increase in power.
27th Jul, 2009 at 06:37:30pm
AC Dodd at ML motorsport will recurve a dizzy for about £45 returned to you. On 11th Feb, 2015 robert said:
27th Jul, 2009 at 06:37:53pm
The three pin connector is really the same as the two pin connector on all the other early electronic dizzys - because only two of the three pins are used.
27th Jul, 2009 at 06:44:32pm
just put it together , time it at max advance ,so at say 4k rpm at 28 degrees ,vacuum pipe off the dizzy ,and use very low boost , ,and dont use boost if you can avoid it unless your set up and sure its rich enough ,,then you can get it set up at a rr . Edited by robert on 27th Jul, 2009. Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
27th Jul, 2009 at 07:10:54pm
the wires go to the top and bottom pins if the one i've got here is right.
