Home > General Chat > water pump flow rate
Chris Dillow
Member #: 6647
Avon Park Class B winner 2010/11
milton keynes
Hi just wondering does anybody no the flow rate of a standard mini water pump or uprated one. I cant seem to find any info about this. Thanks
GaryOS
Member #: 2810
Formally spanner181187
Dublin, Ireland
It's hard to define since it's flow varies with engine speed. AlexF2003 did mention that he would test one but I never found any results.
Off hand, the KAD one has a flow rate of 13l/min and the Meziere one I am using (WP136S) has a flow rate of 2o yank gallons a minute. That's ~ 76l/min. The davis Craig flowrates are listed in their catalogue
On 30th Apr, 2010 Rod S said:
Gary's description is best
Still having problems Chris?
Paul
Chris Dillow
Member #: 6647
milton keynes
yeah just trying to work out best way to mount the water pump and tryin to work out why mine doesnt work as well as yours. How much does a radtec drop the temp down any ideas
It dont mate, get the pump as low as possible and make sure there are no air locks.
GaryOS
Member #: 2810
Dublin, Ireland
What water pump are you using Chris?
Chris Dillow
Member #: 6647
milton keynes
dont really no its got a merc badge on it but it looks the same as the kad/ davis craig one
I had a merc one from a sprinter van.
It was used for the charge cooler apparently, but its not up for the job of cooling the mini annoyingly.
Is there a Bosch Part no on it?
Its the same as mine, so should be OK.
What temp are you getting Chris?
Edited by paul wiginton on 29th Jul, 2009.
Chris Dillow
Member #: 6647
milton keynes
dont no the part no and also dont no what temp it goes up to going to test it on the weekend but it goes up to the red on the std gauge whatever that means????????
