| Home > General Chat > Smokey GT17 - The Damage - Opinions Needed | |||||||
28th Jul, 2009 at 06:05:17pm
Right i have just stripped down my 1752 to inspect the damage and its very clear that the seals on the hot side were completed shafted. The disk/oil thrower thing was saturated in oil. This explained why oil was in the manifold too but not in my head ports. I am guessing that the oil was being thrown up the inlet and wetting the manifold.
Edited by MikeRace on 31st Jul, 2009. 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
28th Jul, 2009 at 06:20:03pm
Yes. That is bin fodder. On 17th Nov, 2014 Tom Fenton said:
28th Jul, 2009 at 06:25:24pm
Wasnt there one forsale recently on the site may be of some help! |
28th Jul, 2009 at 06:37:15pm
I know apbellamy has one! Does anyone know of a blown up diagram of a gt1752. 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
28th Jul, 2009 at 06:57:29pm
its just the ring that does the sealing mike ..its important that its a nice tight but free sliding fit in the groove .. if the groove is worn wider than the ring by much then it wont seal . Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
28th Jul, 2009 at 07:05:42pm
Right, ill go and have a gander 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
28th Jul, 2009 at 08:46:54pm
Right i have just reassemble the just the central part of the turbo and blown down the oil feed and air is pissing out of the hot side. Robert are you sure there is just a clip that goes in to seal it?
Edited by MikeRace on 28th Jul, 2009. 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
30th Jul, 2009 at 02:36:07pm
What rebuild kit did you go for Mike? I'm sure Matty had a problem with missing parts form one supplier. In the 13's at last!.. Just |
30th Jul, 2009 at 02:59:15pm
It wa one of the little collar parts, he machined something down, kit has arrived today so ill see if its ok. 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
31st Jul, 2009 at 12:45:18am
Yeah the kit I got seemed to be a mix and match, got there in the end though!
31st Jul, 2009 at 12:22:39pm
Chaps i have aquired a newe shaft which isnt baldy damage like the other, however when trying to fit the oil seal spring it appears the slot has something in it.
31st Jul, 2009 at 12:28:08pm
Thats looks like a step has been worn into the shaft...same happend to mine.
31st Jul, 2009 at 12:42:42pm
No very tight, as if the collar thing has metled and merged with the shaft?
31st Jul, 2009 at 12:48:29pm
Right mine looks fook all like this one of roberts
31st Jul, 2009 at 01:09:49pm
Mike, I've got two GT17's with loads of play. I'll pull these apart tonight and see if either of the shafts are any good. In the 13's at last!.. Just |
31st Jul, 2009 at 01:10:46pm
Could you not put the shaft in a lathe and take some material out of the slot until you can get a better shaft?? On 11th Feb, 2015 robert said:
31st Jul, 2009 at 01:17:50pm
As a last resort really.
On 31st Jul, 2009 apbellamy said:
Could you not put the shaft in a lathe and take some material out of the slot until you can get a better shaft?? 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
31st Jul, 2009 at 01:24:31pm
Cheers matey. Appreciate it.
On 31st Jul, 2009 theoneeyedlizard said:
Mike, I've got two GT17's with loads of play. I'll pull these apart tonight and see if either of the shafts are any good. 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
31st Jul, 2009 at 04:29:21pm
stuffed if i can make it all out from the pics mike ,...can you get it any clearer ? Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
31st Jul, 2009 at 05:03:05pm
Giz a sec and ill upload some decent pics. 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
31st Jul, 2009 at 05:15:20pm
Right some better slightly blurred pics but it s the best i can do
31st Jul, 2009 at 05:16:03pm
Click the pic and youll get a huge one. 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
31st Jul, 2009 at 06:30:18pm
That's fucked that is :/ On 26th Oct, 2004 TurboDave16v said:
31st Jul, 2009 at 07:27:12pm
mike ,whats happened is the ring has spun ,worn the sides of the slot ,and caried on doing this ,until its made a wide flared groove ,and the deformed metal has blended the bottom of the slot so it looks really thin .ulp ! Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
![]() 834 Posts Member #: 2017 Post Whore Warwick. |
31st Jul, 2009 at 11:46:20pm
the GT15's at my old work were same construction, i used to re-man then and ALOT had wear like yours, exhaust housing full of oil too.
David. |
