| Home > Help Needed / General Tech Chat > turbo head | |||||||
7 Posts Member #: 6749 Junior Member |
29th Jul, 2009 at 10:18:36pm
hello. i have just had the head off my 1275 turbo and need info??? i have been told that i need to have the seats of the exhaust valves changed so that it runs better on unleaded fuel? do i have to do this?? also do i need to get it skimmed when it goes back on? if i do send it to the engineer to be converted shall i get it ported and polished and get some of the meat taken out from the combustion chamber to reduce the compression?? many thanks for any help. i am doing all this on a budget so any work i can do my self would be great. Hugo |
29th Jul, 2009 at 10:42:18pm
Having the head converted to run on unleaded will not make the car run any better, all it does is prolonges the life of the valve seat as the steel hardened inserts will not recess like the standard cast iron on the head eventually does.
30th Jul, 2009 at 09:16:35am
Knock Knock....
Own the day
31st Jul, 2009 at 01:26:19pm
The head doesnt looked warped. i would like the option of running more boost but i want it to be realiable ish!! I have just started lapping in the valves and they do have the steel inserts. thanks for your help phil |
31st Jul, 2009 at 02:37:57pm
On 30th Jul, 2009 Mr Joshua said:
Knock Knock.... The Benros you need to tak to about your head thats who! im sure Benross is very good, But don’t forget that Turbo Phil replied and is more than capable and does quality cylinder head work.. |
31st Jul, 2009 at 05:01:29pm
Seconded |
![]() 1105 Posts Member #: 1504 Post Whore Westbury, Wiltshire |
31st Jul, 2009 at 06:37:55pm
Why did you take it off in the first place ?
31st Jul, 2009 at 07:10:24pm
turbo phil and turbominivan have said it for you unless you want a hi spec head ?
31st Jul, 2009 at 11:01:28pm
i took off the head coz the diff had a big hole in it and the oil pump was cracked. I wanted to know if the engine was any good?? i bought it as seen with cage for £200 |
31st Jul, 2009 at 11:45:31pm
Good price.
2nd Aug, 2009 at 10:35:08pm
the diff and box is dead. the rest is fine |
2nd Aug, 2009 at 11:15:04pm
On 31st Jul, 2009 golfturboy said:
The head doesnt looked warped. Unless you're Superman, this isn't possible. You'll have to get it properly measured. On 13th Jul, 2012 Ben H said:
3rd Aug, 2009 at 10:15:05pm
the head looks fine. it seems to be flat. the engine was taken out coz the gears on the diff pin blew the diff and box to bits with shrapnel. i will try and get pics on??? |
3rd Aug, 2009 at 10:54:39pm
4th Aug, 2009 at 08:29:06am
Remember Vegard, to some people the world is still flat !. |
![]() 453 Posts Member #: 6449 Senior Member Brisbane, Australia |
4th Aug, 2009 at 01:50:27pm
Wouldnt the block get a bit of damage if the gearbox was destroyed by shrapnel?
In boost we trust |
4th Aug, 2009 at 01:58:33pm
Sounds like the usual diff existing through the back of the box, leaving lots of bits of diff, CWP and case inside the sump.
On 4th Aug, 2009 best_stig said:
Wouldnt the block get a bit of damage if the gearbox was destroyed by shrapnel? On 11th Feb, 2015 robert said:
