Home > Show Us Yours! > a little video of what need sorting before MITP!
turbochargedstu
Member #: 908
gateshead
got this far with it and cant really decide what the prob is. out of the 2 carbs, only one lifts, it isnt stuck or anything but if you lift it manually whilst running, it dies. think its still running too lean, even though i have completely removed the jets now!!!
any ideas??
http://s256.photobucket.com/albums/hh167/s...arbsrunning.flv
balls to the blower!!!
im more used to 2 stroke crossers than road bike,s but arent the slides meant to be directly connected to the carb slides? or are yours operates off vac ala su?
my 998 is running 210 jets and I had the needle turned down, on a single VP
turbochargedstu
Member #: 908
gateshead
actually. i have just had a thought. anyone thinking i need a stronger spring in the carb dashpot??!!!
turbochargedstu
Member #: 908
gateshead
it could be lifting too easily and allowing shit loads of air in. thus choking it on hard revs.
have you tried blocking the emulsion tube under the plastic holder for the ram pipe
turbochargedstu
Member #: 908
gateshead
thats the one in the middle isnt it looking at the carbs ? yeah i have blocked off that on both.
supermotolee
Member #: 2153
kings langley
have you checked the rubber diaphragms in the tops of the carbs for splits etc? they can usually be fitted wrong and this can cause the slide not to lift
SC Stu hows it running?
interested to know if you have had any backfires on cranking?
turbochargedstu
Member #: 908
gateshead
i did have some backfires, but not now. just turns over and doesnt fire. i literally have to squirt loads of fuel down to get it to start. i'm off to germany for a week tomorrow too so i'm pushing it to get it finished in time!
turbochargedstu
Member #: 908
gateshead
grrrr still no luck. gallons of fuel going in but still chokes on hard revs
did you fix this? if so hows the car.
working yet?
