Home > Help Needed / General Tech Chat > mpi crank
jakelloyd99
Member #: 5310
Oxford/Hertford
Im replacing my crank due to the flywheel wrecking the taper. Ive got a crank from a mpi engine and wanted to know if its the same taper ect and if i can use it with my pre verto clutch set up. Tried the searching but didnt find anything, Any info would be helpfull,
Cheers, Jake
I bought a new crank from minisport a while ago which was sold as an MPi crank but was exactly the same
jakelloyd99
Member #: 5310
Oxford/Hertford
cheers
