| Home > Help Needed / General Tech Chat > Estimating Compressor Maps | |||||||
5th Aug, 2009 at 11:12:31am
I have been looking for a compressor map for my GT2056V to see if it will suit my BMW M40B18 @ 0.8 bar.
Gary's description is best |
5th Aug, 2009 at 02:31:07pm
I would have thought calculating a comp map for a variable vane turbo would be pretty complex?
5th Aug, 2009 at 03:28:42pm
That was a whole different area I didn't want to start thinking about yet On 12th Nov, 2009 Paul S said:
55 Posts Member #: 6376 Advanced Member oxon |
5th Aug, 2009 at 07:57:53pm
isnt the point of a vane turbo that you can have a variable peak efficency due to the variable ar?
5th Aug, 2009 at 08:06:24pm
garrys correct, tthe vnt only affects the turbine side,
5th Aug, 2009 at 10:18:00pm
Thanks Joe. It's good to know I'm finally getting something right! I'll put that link into favorites. It should keep me busy in work if things stay as slow as they have been On 12th Nov, 2009 Paul S said:
5th Aug, 2009 at 10:52:03pm
Ah of course, i need to stay away giving my opinion when hung over, its a bloody wednesday! A meal and a drink was the plan.... |
5th Aug, 2009 at 10:53:08pm
lol,
6th Aug, 2009 at 10:11:34am
Ah, don't worry James. The only reason I am managing to make any progress and/or sense is because for a couple of weeks a year I get a spurt of enthusiasm, stop drinking, get the hampster turning on that wheel and attempt to justify the life changing amount of money that I have wasted on both cars so far.
6th Aug, 2009 at 12:26:39pm
OK, I have found a GT2056 compressor map with a trim of 55 and an A/R of 0.53. That is ~10% increase in trim and A/R in both figures. Working with that and increasing pressure ratio and air flow figures by 10% gives me a spot just inside the peak efficiency island.
. From my (very limited) understanding, wouldn't VNT be equivelent to a variable turbine A/R though. Would it really have any effect on the compressor side as all we check with the compressor map is peak efficiency at peak boost?
