| Home > General Chat > curious....how turboable is a 1275 MPI ? | |||||||
![]() 3184 Posts Member #: 628 Post Whore a LIL fishing village on the coast - Newcastle Upon Tyne |
5th Aug, 2009 at 03:17:14pm
been offered a sweet deal for an MPI which i am viewing on saturday.
On 17th Aug, 2009 Jay#2 said:
I doubt I'll be dipping into the 13's like you did though! |
5th Aug, 2009 at 03:20:53pm
The standard ECU wouldnt cope so you would either have to do some experimental siamese port injection or drop back onto a carb and use something like megajolt for the ignition.
5th Aug, 2009 at 04:58:30pm
I'd be more concerned with the state of the shell on an MPi though |
5th Aug, 2009 at 05:09:17pm
Actually Agreed!
5th Aug, 2009 at 05:21:02pm
this one is solid, needs an a panel though
5th Aug, 2009 at 06:56:58pm
I think its easyer to ditch all the ecu, injection etc and put a carb and mj on.
998 Posts Member #: 2178 Post Whore Leyland, Lancs |
5th Aug, 2009 at 10:06:37pm
Shouldn't be a problem getting it through an MOT emissions wise if you're friendly enough with your MOT tester. On 15th Jul, 2009 fastcarl said:
a breif struggle ensued but Will emerged the victor with a pair of undies in his possesion On 21st Sep, 2009 apbellamy said:
No, but you did chuck your guts up over my front gate the Saturday before! You even managed to get a bit in your arm pit... |
5th Aug, 2009 at 10:38:34pm
Or your engine number mysteriously changes.....Not that im telling a police officer to do this......just something i heard around town. |
5th Aug, 2009 at 10:43:24pm
LOL,
5th Aug, 2009 at 11:15:15pm
then there is the issue with emisions......mind that said the turbo helps with this a wee bit.
5th Aug, 2009 at 11:22:31pm
changing the lump is easy eniugh, but you have to piss around moving thre alternator or rad, due to the block.
6th Aug, 2009 at 12:51:49pm
Yeah, chaning the lump is fine...however, changing the engine number on the MPI lump to one that falls into a lower emmissions class isnt....
6th Aug, 2009 at 12:57:03pm
In theory you coul knock the number of and say it's an older engine. On 11th Feb, 2015 robert said:
6th Aug, 2009 at 03:23:16pm
Or just put some different plates on it to make it older!? https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
6th Aug, 2009 at 03:32:40pm
So... you're telling a police officer to ring a car?? On 6th Aug, 2009 matty said:
Or just put some different plates on it to make it older!? On 11th Feb, 2015 robert said:
6th Aug, 2009 at 03:55:03pm
All said with tongue in cheek. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
6th Aug, 2009 at 04:09:51pm
You could seriously consider Megasquirt and Jean's siamese code,,,, at least you won't have to build a completely new inlet manifold as some of us have done :)
6th Aug, 2009 at 06:19:31pm
canny...i was hoping not to have to cut the bulkhead on it, basically the car will be run as stock and i will accumulate the bits needed to go on, then once i have em all the mod will begin. ( if the car is as described by my good pal......to be fair it should be as he is of the anal rust busting type mini owner)
(phew think I got away with that one!)
