| Home > Help Needed / General Tech Chat > Oil pump warning | |||||||
27 Posts Member #: 3711 Member Australia S.A |
6th Aug, 2009 at 08:32:23am
Some of the pepole that look at may have seen my thread about my oil pressure problems I’ve been having with my new 998 motor.
Edited by Slo998 on 6th Aug, 2009. |
6th Aug, 2009 at 09:28:56am
well done mate good reserch and interresting indeed.
6th Aug, 2009 at 09:51:12am
Which aftermarket one is it ???
6th Aug, 2009 at 09:58:45am
Out of the two new ones I got one was from Swiftune there “OE spec high flow oil pump for a 998” and one was from a local supplier as the same discription.
6th Aug, 2009 at 10:04:24am
Worrying because that suggests the wholesale source is the same, just going in different bags and boxes.....
Edited by Rod S on 6th Aug, 2009. Schrödinger's cat - so which one am I ??? |
6th Aug, 2009 at 10:26:43am
have you told Swifty? they are the first that should know! I have been using swiftune sourced pumps in two of my engines lately (big bore engines), luckily I seem to have okay pressure. |
6th Aug, 2009 at 10:59:13am
I specilifcally bought the Swiftune 998 pump for my engine, assuming it was of good quality. Luckily I decided to modify an Avonbar turbo oil pump for the 1098 instead. On 12th Nov, 2009 Paul S said:
Gary's description is best |
6th Aug, 2009 at 11:55:39am
The state of new parts lately is not at their best.. all I seem to be doing is replacing new parts that have only been on the car a year or so. I run a supercharger and I don't care the TB is on the wrong side.
6th Aug, 2009 at 12:35:24pm
I have let swiftune know and they said they had not heard of it happing but agreed it was possibly.
6th Aug, 2009 at 12:45:02pm
On 6th Aug, 2009 Slo998 said:
How much work is involved in converting to a metro turbo steel back pump in a small bore? Is it just drilling and tapping for the mounting bolt and a spacer plate? Theres not a whole lot to it. I can't quite remember but I think I had to drill and tap another hole (possibly two). I do remember the other part of the modifications though. We just took the impellor and drive out and shortened the drive by ~10mm. We then just had to cut two flats on the drive. I didn't like the idea of a spacer as it just introduced another gasket which could fail. On 12th Nov, 2009 Paul S said:
6th Aug, 2009 at 01:08:24pm
Excellent I will look into it next time it is apart |
Now there are not too many things to go wrong in one as they are a very simple devise, in case people dont know what is inside one.
Now there is no way in any shape or form that this joint should slip.
