Home > General Chat > One for the BMW Head Guys!
lockfast
Member #: 2775
Aberdeen
Just a quickie! I have been stocking up on bits to embark on my rebuild of my car. My full spec is not quite 100%. Just now I have got a 5 port with a suck through suercharger. I would like to keep my supercharger and have looked into going blow through with injection but I am shying away from the whole siamese code thing! I do howver like the bmw K heads and right now I am swithering about dumping the supercharger and building a NA Bmw head job. But I was just wandering would I have room to fit a suppercharger on with the BMW head and keep a standard round nose? Its an eaton M45 by the way. Just looking for some general opinions for space etc Or has anyone done it?
id have thought that,if you could remote the oil filter ,and maybe put the alternator on the back of the block ,you may ,with a side mount rad ,put the blower in front of the engine on its side ,if itll lubricate itself ok that way.
jbelanger
Member #: 831
Montreal, Canada
It would make for an interesting setup but I find it funny that you're willing to go to all that untried and potentially expensive setup but you're shying away from the siamese code thing.
Jean
http://www.jbperf.com/
Go for it!! *happy*
Anything can be made to fit with a little bit of planning. You would definitely be able to make the most out of the supercharger with than efi setup.
Bracket and mount the charger at the backof the head over the exhaust manifold. LOADS of room back there *hehe!*
Jackman
Member #: 984
Westhoughton, Bolton
Grrrr im never going to get mine done to be the first at this rate unless i just build the engine and sod the estate.
Manchester Minis
*Yes*
lockfast
Member #: 2775
Aberdeen
Jean
I know what you are saying but 4 ports and 4 injectors suits me fine! Pipes and brackets etc I can do! But numbers and other siamese code stuff I am not quite so good at!
