| Home > Help Needed / General Tech Chat > compression ratio (too low?????) | |||||||
20 Posts Member #: 2152 Member skelmersdale, west lancs |
6th Aug, 2009 at 02:37:04pm
hello peoples, after trying to sell my engine parts my interest in all things turbomini has become thoroughly renewed and with my build restarted i calculated my compression ratio to be 7.24:1 and that is if i flush the pistons to the deck of the block. the sums were as follows; RINGLANDS & GASKET = 5cc PISTON DISH = 18cc HEAD CHAMBER = 29cc I was planning on at least 20 psi boost maybe more later on. have i made a booboo or is what i plan feasible? would i be better of changing my pistons to 10cc omegas? my budget will only allow cast pistons if i change them where what ive got now are forged. i calculate the CR with the 10cc pistons to be 8.37:1 again pistons flushed with the deck. what should i do? any help is appreciated, thank you |
6th Aug, 2009 at 02:39:36pm
Is there much work gone into the head other than increasing chamber size? My first thought would be to put a head with smaller chambers on. On 12th Nov, 2009 Paul S said:
Gary's description is best |
6th Aug, 2009 at 02:43:27pm
yes the head is an MED top spec item offset valves 36/32 ported and it would be cheaper to change the pistons |
6th Aug, 2009 at 02:47:26pm
Make some of your money back by selling your pistons and get another forged set? I assume the engine hasn't run yet On 12th Nov, 2009 Paul S said:
6th Aug, 2009 at 02:48:53pm
Just get the head skimmed a touch to get the CR back up a touch.
6th Aug, 2009 at 02:51:31pm
no the engine is yet to be built, i thought a new set of pistons would be easier, i take it from what your saying that 7.24 is too low? thanks gary |
6th Aug, 2009 at 02:56:10pm
i did think of getting the head skimmed but then i thought; would it effect the amount of lift on the valves or is that a silly question? thanks apbellamy |
6th Aug, 2009 at 03:03:34pm
You could also get the block decked, same effect different component On 11th Feb, 2015 robert said:
6th Aug, 2009 at 04:02:40pm
7.24 is awfully low alright. Closer to 8 would be fine. You may have some room to deck the block. It's approx. 0.2mm per cc (as long as my rushed in-head maths is OK) so you would need a big deck height to get the CR near suitable. Skimming doesn't effect lift. If you go mad skimming it can effect rocker geometry but shorter pushrods can be used to compensate On 12th Nov, 2009 Paul S said:
6th Aug, 2009 at 04:04:32pm
7.3:1 is too low tbh, I would change the pistons. If you skim a turbo spec head, you may struggle to sell it on at a later date.
Edited by matty on 6th Aug, 2009. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
6th Aug, 2009 at 05:49:02pm
I would either sell the pistons on to get some with a smaller dish. Or if its been run get a suitable sized turbo and run crazy boost! All depends on what the cars gonna be used for! |
6th Aug, 2009 at 06:24:04pm
Like star mag says ,let people no what you planning on doing with the engine, it may help.
6th Aug, 2009 at 07:07:57pm
30+Psi here we come!
6th Aug, 2009 at 08:26:12pm
Hello again everyone thanks for all your input, it seems that i have a couple of options to go with and to think about. I was building this engine wiyh the odd 1/4 mile in mind but mainly as a second weekend fun car. i dont mind a bit of lag. the reason for me wanting 20+ psi was just for my love of boost. |
6th Aug, 2009 at 10:19:28pm
sorry matty im running a +40 bore 1312 |
7th Aug, 2009 at 12:07:43am
Are you sure your calcs are right ?
7th Aug, 2009 at 04:42:37pm
What size bore/stroke? In the 13's at last!.. Just |
7th Aug, 2009 at 04:44:16pm
i used to run 7.9:1 and 20+psi, now i run about 8.6:1 and 15psi, and it drives better and has does better 1/4 mile times |
7th Aug, 2009 at 09:24:35pm
Steve, dont want to jump thread but wot boost could i run with 7.5:1 ??
On 7th Aug, 2009 stevieturbo said:
Are you sure your calcs are right ? 7.24:1 would be ideal.....if you intended to run say 40-50psi lol But for more mundane levels of boost....aim higher than 8. |
8th Aug, 2009 at 12:43:15pm
Im runnning 8.8:1 and have managed 18psi no probs. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
8th Aug, 2009 at 02:43:01pm
thanks again everyone, ive decided to go the new piston route, 10cc dishes would give me a cr of over 8;1. what do you all think i should ask for my set of unused accralite 18cc forged pistons? still boxed and wrapped. |
8th Aug, 2009 at 04:04:25pm
Whatever you can get for them. At the end of the day...if they are going to give extremely low compression in most engines.....how easy will they be to sell ?
8th Aug, 2009 at 04:49:47pm
I'll give you a fiver for them.
8th Aug, 2009 at 07:24:27pm
ive got an old set of omega 10cc dishes that ill let you have for a fiver but these forged ones have an 18cc dish which is good for an ashtray aswell as a paper weight |
9th Aug, 2009 at 10:32:56am
