| Home > Help Needed / General Tech Chat > Totally losing my mind! | |||||||
27 Posts Member #: 3711 Member Australia S.A |
8th Aug, 2009 at 04:47:20pm
Totally losing my mind right now for the third time I’m having oil pressure problems |
![]() 966 Posts Member #: 358 Post Whore Snetterton, Norfolk |
8th Aug, 2009 at 05:07:50pm
From reading the stuff on Ausmini, the only thing i would try is a new oil pump. As its slow building up pressure and the O.p. seems to be regulated to 65psi with your airline, then that is the only obvious thing it could be. |
8th Aug, 2009 at 05:13:11pm
Yes there are not too many things to go wrong really. The only thing I'm worried about with a new pump is the shaft slipping like I found with the last two I have got.
Edited by Slo998 on 8th Aug, 2009. |
8th Aug, 2009 at 05:23:43pm
With these dodgy oil pumps - especially not knowing if it's dodgy or not - is it worth taking the cover off and putting a couple of very small TIG weld tacks between the shaft and inner rotor ???
8th Aug, 2009 at 06:48:14pm
fit a supaflow pump job done!
