Home > Help Needed / General Tech Chat > Headgasket on 73.5mm bore
retroracer1380
Member #: 1972
Worcester
Hi, what gasket would you run on a 1380 turbo, i was running the af460 copper gasket as i was always told the bk450 overhangs the bore slightly at 73.5mm?
Oli
i've run the bk450 with no overhang probs, I think it can vary block to block.
Turbo Shed
Member #: 30
Epsom, Surrey
as above,
Depends how you had the bores done - I had a slight offset and there are no issues at 73mm so I doubt any at 73.5mm, there are a few photos from me on here.
The AF460 is the better choice, it has a marginaly larger fire ring
retroracer1380
Member #: 1972
Worcester
Cheers for advise
Are you up and running yet?
Scruffy
Member #: 328
Seaford Rise, South Australia
Cometic has no overhang @ 74.6mm - a much better choice - fit and forget!
On 5th Sep, 2011 Vegard said:
my engines a 1380 a slight overhang but no issues whatsoever todate
scruffy, have you a link to this company or supplier ?
retroracer1380
Member #: 1972
Worcester
Couldnt get hold of a BK450 so its back together on another AF460 and some ARPs this time after blowing between no 1 & 2 at the weekend.
Yer Nic its up and running, just gotta take it back down the rollers tommorow,
you will have to pop up and have a look at it!
