| Home > Beginners Tech > fitting larger inlet valves? | |||||||
10th Aug, 2009 at 01:01:56am
hi, im modding my cooper at the moment. its an mpi, so has the smaller 33mm inlet valves. i have modded the head in the past, porting and polishing, having it skimmed to raise cr.
10th Aug, 2009 at 08:27:10am
You don't need any seats installed for the inlets, the existing seat in the head is simply cut larger to suit the valve. Obviously to gain any benefit, both the throat & port will need to bbe worked to suit. |
10th Aug, 2009 at 10:52:28am
Phil's right, but to add. If you're using the standard cam, there is very little to be had changing for a bigger inlet. This is if the head is a good one.
10th Aug, 2009 at 10:45:27pm
as above dan, a change of cam with 35.6mm inlet valves and my thoughts would go to a kent 266 cam would make a good torquey engine
10th Aug, 2009 at 11:04:28pm
well the engine i have planned is as follows.
11th Aug, 2009 at 08:12:45am
With that spec, the 35.6 valves will likely give you a gain in top end, but rob you of midrange torque. The 1.5 rockers won't ghelp this either. What do you want from the engine? On 13th Jul, 2012 Ben H said:
11th Aug, 2009 at 12:33:22pm
With that spec I would argue at having a more breathable exhaust think about upping it to 2" and sourcing somthing other than an RC40 I ran much the same many moon's ago and the thing pulled like a train and would eat anything upto 1800 in an all out drag. Top end was around 125 indicated Own the day
11th Aug, 2009 at 01:49:09pm
There's no need for a 2" exhaust on a Sw5 cam no matter what the other specs are. On 13th Jul, 2012 Ben H said:
11th Aug, 2009 at 03:55:52pm
what i want from the engine is as quick an mpi as possible, with as much power and torque that can be obtained with the constraints of the standard ecu. the ecu will be the limiting factor regarding power.i would hope for anywhere between 70-90bhp
11th Aug, 2009 at 04:18:32pm
For a road engine I don't need power above 5500rpm. All my driving is below this. Apart from the occasional burst. What I want from a road engine is as much torque I can get below in this rev band. For this I would think the 33mm inlets and 1.3:1 rockers would be my choice with a SW5. If you want the maximum amount of power the engine can deliver, 35.7mm valves and 1.5:1 WILL increase maximum power, but it will also rob you of midrange torque. It depends on what you want from the engine.
13th Aug, 2009 at 04:42:01pm
i always thought that 33mm inlets restricted even standard 1275 engines. i understand the smaller the valve the higher the velocity, ie more torque. though i thought that the 33 inlet restricted power and torque due to it being so small? |
17th Aug, 2009 at 11:22:40am
