| Home > Help Needed / General Tech Chat > Uprated pads for fiesta calipers? | |||||||
![]() 667 Posts Member #: 5232 Post Whore basingstoke |
10th Aug, 2009 at 07:56:25am
Hi guys, I'm in need of some new pads for my fiesta brake setup, which uses mk2 calipers I believe:
Mr. Prawn, the friendly Crustacean- slowly making steps towards forced induction. |
667 Posts Member #: 1376 Post Whore clock tower with a sniper rifle |
10th Aug, 2009 at 08:07:58am
Also very intrested in this, i run ferodo road pads now, was thinking that maybe a pad from a more "performance" ford caliper would fit (i´m ok with some grinding etc) ds 2500´s would be lovely!
Edited by G13B on 10th Aug, 2009. internationally known as "big" swede |
10th Aug, 2009 at 08:13:28am
I'm eventually going to upgrade to alloy 4 pots, but having just spent £600 sorting out the dailly, I can't afford much at the mo, so fast road pads in these it has to be! Mr. Prawn, the friendly Crustacean- slowly making steps towards forced induction. |
![]() 3184 Posts Member #: 628 Post Whore a LIL fishing village on the coast - Newcastle Upon Tyne |
10th Aug, 2009 at 08:29:13am
just go online and get some comp pads for them, i always throught that the fezzy route was done with Mk1 callipers but the banjo appeasr to be in the wrong position for a mk1 calliper. there are still many of these about so i am sure there are uprated pads.
Edited by Richie on 10th Aug, 2009.
On 17th Aug, 2009 Jay#2 said:
I doubt I'll be dipping into the 13's like you did though! |
10th Aug, 2009 at 08:36:07am
mk1 or 2 calipers work just fine, as you said, the hose take off is in a different location on the mk2 caliper.
10th Aug, 2009 at 01:58:05pm
Just spoke to Demon tweeks, they can get mintex 1144 pads in the 141mm height for the mk2 caliper, for £53. They are special order from mintex though, so may take a few weeks to arrive. Mr. Prawn, the friendly Crustacean- slowly making steps towards forced induction. |
11th Aug, 2009 at 11:13:37am
are the mintex calipers better than green stuff/shite? internationally known as "big" swede |
25th Aug, 2009 at 05:05:15pm
quiock update on this one guys.....
30th Oct, 2009 at 11:19:32am
Did these fit? I know the XR2 ones dont as I had a set, they fit in the carriers but are too wide and make contact on the side of the slide so wont touch the disc... I run a supercharger and I don't care the TB is on the wrong side.
30th Oct, 2009 at 11:22:48am
they do indeed!
30th Oct, 2009 at 11:38:10am
where did you get them? got any codes? I run a supercharger and I don't care the TB is on the wrong side.
30th Oct, 2009 at 11:44:41am
from Demon tweeks, they were actually really helpful, and spent ages on the phone looking through loads of different pad types and stuff until they found one they were sure would work.
30th Oct, 2009 at 11:46:38am
I got a set of Mintex's 1144 for feza calipers the other day only took 3 days to get, I think I still have the box in the workshop I get the number for you If I can :) On 17th Feb, 2009 Rob H said:
30th Oct, 2009 at 12:11:21pm
Thanks - They are only down the road from me..
