| Home > Technical Chat > few questions i cant find answers for :( | |||||||
10th Aug, 2009 at 02:09:02pm
some random questions i have not been able to find answers for any help appreciated :)
Edited by Brett on 10th Aug, 2009. Yes i moved to the darkside |
![]() 673 Posts Member #: 1395 Post Whore chepstow |
10th Aug, 2009 at 08:18:10pm
2) Standard 1st is straight cut anyway
![]() 646 Posts Member #: 1826 Post Whore Maldon Essex |
10th Aug, 2009 at 09:19:28pm
5. yes you can get an mot with 1 seat
10th Aug, 2009 at 10:48:31pm
On 10th Aug, 2009 andywaller said:
5. yes you can get an mot with 1 seat Yes, it is only an advisory without a passenger seat if the seat belt is still fitted Mind you I would think it would be a fail if it was the drivers seat that was missing
2497 Posts Member #: 1954 Post Whore Luton Bedfordshire |
11th Aug, 2009 at 12:58:15am
Straight cut drops will save your transfer caseing. If your engine is from a car pre 1983 then emissions test are waved. Own the day
11th Aug, 2009 at 08:38:24am
If you're racking up 5000miles a year SSC drops is a BAD idea. On 13th Jul, 2012 Ben H said:
11th Aug, 2009 at 09:04:00am
Pre 1983, the emmisions level (can't remeber whether CO2 or hydrocarbons) is uped from 3.5% to 4.5%
11th Aug, 2009 at 10:04:20am
On 10th Aug, 2009 Sprocket said:
Mind you I would think it would be a fail if it was the drivers seat that was missing ![]()
On 11th Aug, 2009 Vegard said:
If you're racking up 5000miles a year SSC drops is a BAD idea. is this just due to the sound they make? i can live with that, its the wear rate im worried about i seem to remember the emissions limit used to be 3.5%CO and 1200ppm its an 1986 car im not going to mention the engine swap lol cheers the gaps are getting filled in:) Yes i moved to the darkside |
![]() 695 Posts Member #: 984 Post Whore Westhoughton, Bolton |
11th Aug, 2009 at 10:30:55am
I also want to know why sc drops is a bad idea. i do 11k a year with them and they are coming upto 20k in the engine i think. |
3596 Posts Member #: 655 Post Whore Northern Ireland |
11th Aug, 2009 at 10:37:16am
On 10th Aug, 2009 Brett said:
some random questions i have not been able to find answers for any help appreciated :) 1) pistons, id like to stay std 1275 bore but as far as i can make out the only 'turbo' piston in std bore is the original metro ones - anyone know of any others? or run boost with std spi cooper pistons? you can get custom pistons made in any shape or form you want. Std metro turbo pistons while heavy, are very very strong. 2) gearbox, im considering a straight cut gear set now to try and future proof as much as possible the evolution gear set from minispares gets good press (especialy by mr Benross) but it doesnt replace first gear iirc doesnt that make first gear the next weakest gear? lower gears tend to have less strain put on them as the car appears lighter due to gearing etc. Plus as others said, its SC anyway. 3) what is the wear like on the straight cut gears, i plan on using the mini as much as possible and could be racking up 5k+ per year? I ran mine for about 30k per year when I drove my car....only issue I had was teeth breaking off occasionally lol 4) mot and a new engine, i will have to mot this mini with a brand new engine with maybe 10miles on the clock if that would it make getting good emissions difficult? If the carb is setup right, and the cam is mild, emissions shouldnt be overly difficult. 5) do u recon i can get an mot with only 1 seat?
i will have more to come :) thanks in advance for any help cheers Brett ![]() MOT only check whats there. No problem with one seat, as long as its secure, and has a seat belt. 9.85 @ 145mph
