| Home > Help Needed / General Tech Chat > Can someone help me? I'm struggling to dump!!! | |||||||
![]() 71 Posts Member #: 2328 Advanced Member Nr Newmarket, Suffolk |
10th Aug, 2009 at 09:22:58pm
100% BMW Free |
10th Aug, 2009 at 09:26:21pm
whereabout on your inlet does it come from? not through the one way valve on the servo take-off is it? On 20th Oct, 2015 Tom Fenton said:
21 Posts Member #: 6195 Member |
10th Aug, 2009 at 09:31:44pm
ive got mine teed off from the pipe that used to go to the brake servo, took out that valve as i dont have a servo, and just used a t piece into that pipe, one for bailey one for guage. |
10th Aug, 2009 at 09:36:24pm
I've got it on the pipe that would normally run to the vacuum advance on the dissy. My boost gauge works with no problem at all off the same one. 100% BMW Free |
10th Aug, 2009 at 09:47:05pm
on my setup it came directly from the manifold, i found that when the throttle was completely closed (well near enough ) the vac advace take off gave no vacuum Yes i moved to the darkside |
10th Aug, 2009 at 09:56:29pm
With the throtle closed the vac advance pipe sees no vacuum as it is on the plenum side of the throttle disc, not on the manifold side. Idealy drill and tap a conection on the acutal manifold or use a sandwich plate between the carb and manfold with a take off on that. On 7th Nov, 2008 Nic said:
10th Aug, 2009 at 10:05:38pm
O right that makes sense. So the boost gauge will work off the vacuum advance take off but the dump valve might not. Is this www.minispares.com/Product.aspx?ty=pb&pid=36947&title=MANIFOLD%20ADAPTOR%201.75 the sandwich plate you're talking about? Edited by Guennie on 10th Aug, 2009. 100% BMW Free |
10th Aug, 2009 at 10:59:40pm
the boost gauge will work off it but won't show a proper vacuum figure iirc? On 20th Oct, 2015 Tom Fenton said:
10th Aug, 2009 at 11:41:13pm
TBH the original vac advance is rubbish for most things, as Nick says it's not great for the boost gauge either. I use it for megajolt but on over run with the throttle closed it reads atmosphereic and doesn't give enough advance. That spacer with the vac takeoff should work, mine has a 2-3mm take off which flows enough to trigger the dump valve. I tried using the part throttle lean off pipe conection as a dump valve trigger but that doesn't work. Edited by Jay#2 on 10th Aug, 2009. On 7th Nov, 2008 Nic said:
11th Aug, 2009 at 08:13:05am
The part throttle lean off pipe will work if you run a 1/8 drill through it first - at least it did on mine.
11th Aug, 2009 at 12:41:21pm
I am moving mine to the Banjo for the break servo. By removing the valve which I believe came from the air filter housing allows you to fit a NPT fitting to tap your dump valve to. Own the day
11th Aug, 2009 at 01:51:45pm
Thanks for the info. Hopefully i'll be picking up the spacer with vacuum take off at mitp, so i'll fit it there and dump all the way home! 100% BMW Free |
![]() 1105 Posts Member #: 1504 Post Whore Westbury, Wiltshire |
11th Aug, 2009 at 02:58:22pm
I'm with Mr Joshua on this.
298 Posts Member #: 1357 Senior Member telford,shropshire |
11th Aug, 2009 at 11:04:35pm
i used the sandwich plate thing from minispares and connected my dumpvalve to it, and all i got was a long and delayed shhhhhhhhhhhh sound.
'always keep a spare shot for a stray bird' |
26th Aug, 2009 at 11:07:12pm
On 11th Aug, 2009 fordimus maximus said:
i used the sandwich plate thing from minispares and connected my dumpvalve to it, and all i got was a long and delayed shhhhhhhhhhhh sound. on inspection, the take off was not a straight threw hole, so connected dumpvalve to take off from inlet, and bob was my uncle. I got mine through the post today and fitted it and am having the same long, delayed shhhhhh sound you describe. The take off on the inlet you mention, is that one you drilled and tapped yourself? Could i drill out the takeoff on the spacer so its a straight threw hole? 100% BMW Free |
29th Aug, 2009 at 10:09:48pm
you may be able to to yeah, ive just used a drilled take off from the manifold. 'always keep a spare shot for a stray bird' |
11 Posts Member #: 6745 Member |
29th Aug, 2009 at 10:27:38pm
I did the same as mr joshua exept I used a big bleed nipple off a truck or something easy! works a treat |
