Home > Wanted > 15PSI MAX BOOST GAUGE
998turbomini25
Member #: 2276
sheffield / derby
Hi guys
has any one got or know where i can get a boost gauge that at maximum reads 15psi?? The reason i ask is the sc12 setup is only running 7-8 psi, and most gauges will hardly show the movement of the needle!! let alone have readable divisions.
thanks luke
I have a brand new white faced TIM 1bar boost gauge. Been out of the box a couple of times but never installed £20?
BTW 1bar= approx 14.5psi
Also am local so could drop off.
not cheep, but...
http://www.merlinmotorsport.co.uk/p5732/SP...oduct_info.html
metroturbo
Member #: 989
North Yorkshire
I am using a gauge that is 20 psi boost. It might be near enough for what you need, and it wasn't that expensive when I bought it.
http://www.autogauge.com.tw/web/products/c...categorysubid=4
