| Home > General Chat > Bore lip removal tool name | |||||||
11th Aug, 2009 at 12:44:24pm
Whats are these called?
11th Aug, 2009 at 12:48:32pm
honing tool On 11th Feb, 2015 robert said:
11th Aug, 2009 at 12:52:56pm
I just use a 3 legged honing tool too....just hang it out of the bore a bit and let the stones run at an angle. 9.85 @ 145mph
11th Aug, 2009 at 01:22:29pm
that looks fancy, i've never seen one like that before, TBH, i've if needed just used some course wet and dry paper to help the rings on there way into the bords. Best 1/4 mile 13.2 seconds @116 mph
![]() 1105 Posts Member #: 1504 Post Whore Westbury, Wiltshire |
11th Aug, 2009 at 02:42:47pm
Glaze buster Minivanless, but reluctantly happy living with the decision. There'll be another one day.
11th Aug, 2009 at 04:43:27pm
file Isambard Kingdom Brunel said:
11th Aug, 2009 at 04:49:38pm
dremel |
11th Aug, 2009 at 05:37:41pm
lol, worse than mallets mallet
11th Aug, 2009 at 05:39:25pm
I was being serious, I always use a small file to put a radius on the top of the bore. Isambard Kingdom Brunel said:
11th Aug, 2009 at 06:37:36pm
are we talkign a tool to chamfer the bore, or a tool to remove the ridge in a standard(or used) bore above the area swept by the first ring? turbo 16v k-series 11.9@118.9 :)
11th Aug, 2009 at 07:01:38pm
get rid of the wear ridge above the top ring "Turbo's make torque, and torque makes fun"
559 Posts Member #: 2775 Post Whore Aberdeen |
11th Aug, 2009 at 07:20:08pm
I use wet and dry for the worst of it and finnish of with the honing tool |
11th Aug, 2009 at 07:24:31pm
i scrape away any carbon, then get a honing tool in there :) turbo 16v k-series 11.9@118.9 :)
348 Posts Member #: 2253 Senior Member Las Vegas, Brit in the States |
11th Aug, 2009 at 07:25:17pm
bore reamer?
11th Aug, 2009 at 07:53:41pm
On 11th Aug, 2009 miniboo said:
11th Aug, 2009 at 08:11:23pm
Called a piston ridge reamer here and its cheap as fook:
Edited by miniboo on 11th Aug, 2009. |
11th Aug, 2009 at 08:21:13pm
9" grinder 9.85 @ 145mph
11th Aug, 2009 at 09:37:43pm
mini boo, thats the sort of thing i was looking for, but its 3" to 5" adjustable, and the little 63mm bore on the 998 is just a little too small
