| Home > General Chat > Stupid gearbox question | |||||||
11th Aug, 2009 at 03:28:54pm
Need to have a box refreshed for the van. I've only got one from a 998 lying round. Will that go straight on with the 1275 drops or do I need to do anything else?? On 11th Feb, 2015 robert said:
11th Aug, 2009 at 03:33:43pm
all A+ boxes are the same bar final drive iirc Yes i moved to the darkside |
11th Aug, 2009 at 04:08:49pm
not , ratios are not the same , 1275 have a taller first gear. |
11th Aug, 2009 at 04:12:48pm
Would a shorter first gear be a problem with a turboed 1275 running about 10 psi and 3.2 final drive?? Edited by apbellamy on 11th Aug, 2009. On 11th Feb, 2015 robert said:
11th Aug, 2009 at 04:45:50pm
probably not, |
493 Posts Member #: 3894 Senior Member sallys gap. garden of Ireland |
11th Aug, 2009 at 06:31:11pm
10 psi with a 3.44 final drive on mine and running 10's, i feel i have to change to second too soon. as it revs out very quickly and cant build up much boost.
11th Aug, 2009 at 07:00:54pm
fit a taller diff then.
11th Aug, 2009 at 07:05:28pm
It will be on the Metro Van, so it's 13" wheels and 3.1/3.2 CWP depending on what we can get at the right price. On 11th Feb, 2015 robert said:
11th Aug, 2009 at 07:18:50pm
look for a 1275 gt gearbox!
11th Aug, 2009 at 07:54:37pm
It's a budget build from bits we have lieing round or picked up on the cheep.
11th Aug, 2009 at 08:13:56pm
a 998 box may well have a 3.1 in it |
11th Aug, 2009 at 08:44:21pm
It came out of the van originally. Low comp 998, with IIRC a 3.44 unfortunatly.
11th Aug, 2009 at 11:05:05pm
On 11th Aug, 2009 apbellamy said:
Not that there's anything stopping me counting the teeth on the Crown wheel.... Probably worth counting the ones on the pinion too.... otherwise you will get a "divide by zero" error message in your maths
12th Aug, 2009 at 05:17:48am
On 11th Aug, 2009 fab said:
not , ratios are not the same , 1275 have a taller first gear. did not know that lol bang goes my plan of rebuilding the 998box for the turbo then :( Yes i moved to the darkside |
12th Aug, 2009 at 08:06:13am
Not that there's anything stopping me counting the teeth on the Crown wheel.... Probably worth counting the ones on the pinion too.... otherwise you will get a "divide by zero" error message in your maths ![]() On 11th Feb, 2015 robert said:
12th Aug, 2009 at 08:58:13am
I see your point - there's a table here that might help
Edited by Rod S on 12th Aug, 2009. Schrödinger's cat - so which one am I ??? |
12th Aug, 2009 at 09:05:20am
That's usefull. Thanks Rod.
12th Aug, 2009 at 10:39:36am
phnarr phnarr |
591 Posts Member #: 360 Stu from Corwall aka Mr Jazz Piano, Love_Machine, kneegrow |
12th Aug, 2009 at 12:39:07pm
I would avoid a 3.44 and an A+ box on 10" wheels. 1st was useless and it was unbearable at about 80.
Bugger off, I'm getting there. |
12th Aug, 2009 at 01:44:55pm
its a bit of a screamer alright, and in stereo with the missus in the passenger seat off the lights! |
![]() 453 Posts Member #: 6449 Senior Member Brisbane, Australia |
12th Aug, 2009 at 02:18:13pm
it was all i had at time and just wanted it built
how does the 998E box differ ratio wise? Ive got a 3.44 diff on a near stock 998 on 10s and its too low geared. With a turbo i wouldnt be able to change gears quick enough. In boost we trust |
12th Aug, 2009 at 09:28:01pm
its exciting ill say that, but with s/c drops the noise takes some getting used to!!!
12th Aug, 2009 at 09:48:47pm
is this not a good thing? it running like an n/a in first with less wheelspin?
On 11th Aug, 2009 1972-ANGUS said:
10 psi with a 3.44 final drive on mine and running 10's, i feel i have to change to second too soon. as it revs out very quickly and cant build up much boost. for me a taller first would be great. Drives
12th Aug, 2009 at 11:11:24pm
Doesnt the 998E have a 2.95? |
13th Aug, 2009 at 10:18:50am
indeed for that it works a treat, but its always a compromise as 80mph comes at something silly like 6000+ in top. and as its a daily drive, economy is out the window.
On 12th Aug, 2009 Paul R said:
is this not a good thing? it running like an n/a in first with less wheelspin? On 11th Aug, 2009 1972-ANGUS said: 10 psi with a 3.44 final drive on mine and running 10's, i feel i have to change to second too soon. as it revs out very quickly and cant build up much boost. for me a taller first would be great. |
