| Home > General Chat > Turbo head convertion | |||||||
1171 Posts Member #: 107 Post Whore Sunny Sussex |
29th Nov, 2004 at 11:41:52am
got me a turbo head, its leaded. is it ok to have it converted as per normal heads or are there any special doo's or dont's? Also, by sticking it on my 1293, wha sort of comp ratio would that give me?
29th Nov, 2004 at 12:35:36pm
It should be fine to convert...
AlexF |
29th Nov, 2004 at 01:10:59pm
what method do u use? the plastic over the bore and fill with fluid method?
Edited by Mike on 29th Nov, 2004.
29th Nov, 2004 at 02:16:22pm
you need to consider lots of factors as well as piston and head volume... but you sound like your on target.
AlexF |
29th Nov, 2004 at 03:14:17pm
true, i'm after something thats reliable and drivable not a 180bhp monster. infact i'll be well happy wilth 100-110 tbh
29th Nov, 2004 at 05:05:40pm
std engine... morspeed stage 3 head.... 8psi
AlexF |
29th Nov, 2004 at 05:12:49pm
k'nell
29th Nov, 2004 at 09:11:53pm
std is 94... so thats only 26 more.... with a much better head and a turbo thats not unreasonable!
AlexF |
29th Nov, 2004 at 10:34:33pm
so what ARE the bloody differences between a std 940 and a turbo 940? can i 'convert' my lovely fresh 940 into a turbo compatible one?
30th Nov, 2004 at 08:18:47am
coolant passages in the head itself and the exh valves are sodium filled.
AlexF |
30th Nov, 2004 at 09:21:49am
y the reason for asking is i have a head thats only just been reconned with new guides, converted to unleaded and 11 stud, and would like to use that. The valves however are the std ones, so if i change those to a better quality i can run std boost give or take a few psi. Not after huge boost.
30th Nov, 2004 at 10:19:21am
Valves might be ok...
AlexF |
