| Home > Help Needed / General Tech Chat > oil pressure problem | |||||||
124 Posts Member #: 1126 Advanced Member peterborough |
11th Aug, 2009 at 09:56:25pm
Hey everyone, could do with some help or reassurance, not sure which yet! Had a good search but cant find any problems the same as mine. Fitted the turbo this week end and all seemed to be well after a few teething problems. Now things are running great, all pressures as before until you stat to push on, then say ten mins of semi hard use the oil pressure drops! My guess is oil temp is getting to high but searching has made me think maybe not. Before the turbo was fitted it was as steady as a rock at 20/30 at idle warm 60 plus when reving. Now as before until you use any boost, as soon as you do 5/10 mins later you only get mabey 50 at full chat dropping to 10 on idle, full pressure never returns till stone cold again then same as before.
11th Aug, 2009 at 10:02:32pm
10/40 is a bit thin in my opinion,
11th Aug, 2009 at 10:16:04pm
was planning a new rad, oil temp gauge and cooler this week end and was really not that concerned till i searched now im thinking knakered pump, mains etc, lol. Its an ongoing project and getting a bit worried about it going on the rollers till this is fixed. Better oil first step though, would ign timing make a difference by heating up thigngs exhaust side? I'm thinking the oil may be picking up a lot of heat from the turbo? running 10 deg at the mo. |
11th Aug, 2009 at 10:37:39pm
well as i said 50psi is ok, i always like to see 25psi+ at idle, but 10 psi isnt that bad.
11th Aug, 2009 at 10:51:08pm
no idea about the stat, will check and change though, think im gonna keep away from the rollers for now though. Thanks mini13, will go with it for now, take a few steps at a time and see if i can improve things. The motor has only got to last out the summer. Just so tempting to hit the gas! Love it and def the best thing iv done so far :) |
11th Aug, 2009 at 10:53:29pm
Sorry forgot to say engine is about 60k. |
11th Aug, 2009 at 11:11:11pm
The drop in pressure is more likely to be just that the turbo is now taking some of the flow and the pressure therefore drops a littleas soon as it gets a bit hotter than it did when N/A but it does not sound bad enough to warrant a strip - yet. |
12th Aug, 2009 at 08:44:14am
Oil temp gauge is FAR more important than a cooler. Do it. On 13th Jul, 2012 Ben H said:
12th Aug, 2009 at 09:38:43am
10/40 is no good put in there 20/50
12th Aug, 2009 at 09:46:30am
I wouldn't worry too much. Remember that the turbo engines did have a larger capacity oil pump to deal with the extra flow required through the turbocharger, so if you are running the standard pump then it is logical that your pressure will have dropped slightly now it is feeding the turbo.
![]() 1105 Posts Member #: 1504 Post Whore Westbury, Wiltshire |
12th Aug, 2009 at 01:22:48pm
Keith.
Edited by turbominivanman on 12th Aug, 2009. Minivanless, but reluctantly happy living with the decision. There'll be another one day.
12th Aug, 2009 at 04:18:14pm
excelent! Should have known when asking for oil for a metro turbo and the guy said "is that diesel or petrol?" he didn't have a clue what he was talking about! Thanks for your speedy and helpful advice chaps, feel much happier now :) |
12th Aug, 2009 at 06:56:55pm
The relief valve has no effect on idle oil pressure.
12th Aug, 2009 at 06:59:09pm
Mine behaves in a similair way and i have 10/40 in, will be swapping to 20/50 before mitp. Edited by MikeRace on 12th Aug, 2009. 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
14th Aug, 2009 at 03:55:23pm
Just to update on this, i now have 20/50 and the pressure has upped around 10psi on idle and doesnt fall when hot 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
14th Aug, 2009 at 04:18:49pm
Excellent!
14th Aug, 2009 at 05:49:07pm
I liiikee 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
14th Aug, 2009 at 05:50:20pm
Are those gianna michaels wobblers? 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
14th Aug, 2009 at 06:34:52pm
14th Aug, 2009 at 07:28:29pm
Yahh, no more smoke! 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
14th Aug, 2009 at 07:41:05pm
Yet... On 11th Feb, 2015 robert said:
14th Aug, 2009 at 08:13:14pm
On 14th Aug, 2009 MikeRace said:
Are those gianna michaels wobblers? nope ,brandy Taylor, carl |
15th Aug, 2009 at 04:25:04pm
Put new 20/50 plus some stp in this morning, yippee :) all is well again, bit down on before but thats to be expected. Now just need to figure out how to keep it cool and i can start turning the boost up yay. Thanks for the help. |
