Home > For Sale > Spark plug indexing washers
Im testing some new indexing washers at MITP (as long as the weather holds up).
I have them fitted to my car now and they line the plugs up perfectly.
Made from copper they come as plug sets 1x small, 1x medium, 1x large, obviously you will want 4 plug sets and cost you £9 plus postage @ 50p
The small will rotate the plug 35 degrees
The medium 90 degrees
The large 180 degrees.
On a 2 valve Mini engine the open side of the electrode should face the the exhaust valve.
Any interest? I should be able to bring some with me to MITP
Paul
Are you at that point with your engine Paul? Optimising the plug nose position in an effort to improve performance, however small?
Cool!!! :)
Yes, nothing more can be gained.
If plug gap matters though, surely its position must also
Paul
masybe surface discarge plugs are worth a go.
indexing the plugs is worth 2hp on 180 hp pinto,i am reliably informed,
PaulH
Member #: 2340
Dublin Ireland
I will take a set Paul :)
On 17th Feb, 2009 Rob H said:
tadge44
Member #: 2500
Buckinghamshire
For a minute there I had to check the calendar to see that it wasn,t April 1st then I saw the names of the contributors - sorry guys.
Paul, you can Paypal me or collect from Pod
Paul
PaulH
Member #: 2340
Dublin Ireland
Ill grab them of you at pod
OK Paul, reserved yours, not got many left now.
Forgot to mention they come with full fitting instructions - not that its difficult
Paul
sweet heart, will fitting this drop the CR slightly?
Honey, yes but the thickest ones are only around 1mm thick so over the area of the spark plugs diameter, not enough to worry about.
Paul
Only 5 sets left now from this batch
Paul
Now that's what I call service (as usual Paul).
Got mine this morning, shall be fitting them later.
got mine thanks
I have another batch of these if interested
Paul
i would like a set
but dont have a clue as to what they do......
NICE HAHA
Spark plug indexing is the process of rotating the open face of the plug (i.e. opposite the ground electrode) to face a certain direction within the combustion chamber.
This is to enhance combustion efficiency.
For multi valve engines, indexing the plugs so that the open face points towards the inlet valves usually works best. For 2 valve engines, pointing towards the exhaust valve usually works best.
These are copper washers made to the correct thicknesses to give 35, 90 and 180 degree rotations. These kits are supplied as 3 different sizes per plug, so there are 12 washers in total.
These can be removed from your plugs and reused on a new set when replacing so last for years.
Full fitting instructions are supplied
Paul
Go on paul I'll have a set for the crack.
PM coming your way.
oh i see now ..... *Cloud 9*
i think on a master peice like your sprint these are benificial, but on my truck....no, so for that reason im out......
lol
On 10th Sep, 2009 paul wiginton said:
NICE HAHA
Paul
Disk full (/tmp/#sql_c9d4b_0.MAI); waiting for someone to free some space... (errno: 28 "No space left on device")
