| Home > Help Needed / General Tech Chat > Megajolt Outputs + relays | |||||||
13th Aug, 2009 at 08:21:12am
Hi all just wondering if anyone can help. I would like to use an output on my mj to control the clutch on my super charger. I have MJ V4
13th Aug, 2009 at 08:47:35am
I will be doing something similar for the fuel pump using my MJ V4. Not tried it yet, but was told it was feasable.
41 Posts Member #: 2397 Member Plymouth |
13th Aug, 2009 at 01:12:56pm
The user outputs are negative switching so you would connect the user output to pin 85 on your diagram. You would remove the current earth connection and leave the switch on. Examples can be found here: http://www.autosportlabs.net/MJLJ_V4_vehic...tallation_guide |
13th Aug, 2009 at 02:11:07pm
What he said^ Outputs are 0V.
13th Aug, 2009 at 02:28:00pm
cool so keep the charger earth but disconnect 85 and connect the MJ output.
