| Home > Paul S trials and testing > Datalogs from MITP | |||||||
16th Aug, 2009 at 05:46:45pm
Couple of logs from MITP. Sturgeo was driving and will post his times later.
16th Aug, 2009 at 05:56:52pm
I guessed you would post as soon as you could...
16th Aug, 2009 at 06:34:00pm
It was the fastest 998 EFI Turbo at MITP Edited by Paul S on 16th Aug, 2009. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
16th Aug, 2009 at 06:52:35pm
AFR match is really good but it seems the outers are leaning out a bit at high RPM. So, as you say, you probably need to increase fueling a bit.
16th Aug, 2009 at 08:36:17pm
On 16th Aug, 2009 sturgeo said:
I managed a 17.0 @ 79mph with a 2.6 60ft. Also got a near identical 17.0 but terminal speed was 71mph and that had a 2.7 60ft. We need some gear dependant boost control as the tyres were loosing traction all the way through first and the logs just show it sat at 6000rpm for a few seconds :) A good day though, my first attempt at drag racing and i enjoyed it, will hopefully go to a few more rwyb as the pod is only 15mins away from home. Just need to get the racer ready for october
edit: 998cc efi turbo with a non strip friendly 2.95 diff I'm dead chuffed with that. A full 2 1/2 seconds quicker than my attempt at Avon. With a bit more boost though. Not spectacular but good for a full weight road car with the spare wheel and jack in the boot. The sort of times that you would expect from 115hp. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
857 Posts Member #: 1778 Post Whore Northants |
16th Aug, 2009 at 08:40:20pm
that 2nd log baffles me, i dont know whats going on at the start... |
16th Aug, 2009 at 09:08:30pm
I didn't notice before, I was only looking at the red/yellow traces initially, but I agree, MAP is all wrong at the start.... Schrödinger's cat - so which one am I ??? |
16th Aug, 2009 at 09:15:37pm
That second trace is very odd.
17th Aug, 2009 at 07:50:51am
Are you reading MAP from the MS or the Innovate kit ? Schrödinger's cat - so which one am I ??? |
17th Aug, 2009 at 08:27:27am
MAP comes from the MS. That reading matches the brand newboost gauge so I'm happy with that.
17th Aug, 2009 at 09:42:09am
So what's the max RPM now? seems to be 6k in first and second, then hold on a bit more in third.
17th Aug, 2009 at 09:59:25am
The rev limiter is set at 6250rpm, so that you can actually get to 6k without it hitting the limiter.
17th Aug, 2009 at 10:51:26am
I built mine with similar objectives, and 7k is for race use only really.
17th Aug, 2009 at 11:36:34am
We've not had time to work on optimising the cruise settings yet.
17th Aug, 2009 at 11:41:43am
I know that feeling!
17th Aug, 2009 at 12:15:06pm
just a thought, megalog veiwer does an mpg calculation if you put your gear ratios into it, its only what its doing right at that moment, but could be used to compare two cars at say 50 iin 4th.
