| Home > Help Needed / General Tech Chat > Turbo smoking at idle and breathers blowing oil | |||||||
![]() 465 Posts Member #: 1972 Senior Member Worcester |
16th Aug, 2009 at 09:11:54pm
Just got back from mitp pretty pissed as i couldnt run as its chucking out clouds of blue smoke at idle, i realise this is the turbo seals. Thing is ive put 3 second hand turbos on and they all work ok then they eventually start smoking at idle. Obv this time il fork some money and get a turbo rebuilt, but I spoke to turbotechnics a while ago and they said it could be not enough back pressure allowing the seal to leak or my oil return not letting the oil flow back quick enough.
16th Aug, 2009 at 09:23:54pm
smoking out the breathers tends to be pistons or piston rings |
16th Aug, 2009 at 09:39:05pm
As above, smoke out the exhaust at idle can easily be turbo oil seals, oil pressure pumping oil to be burnt in the exhaust, but smoke out the breathers at idle is crankcase pressure, ie, rings or pistons. Schrödinger's cat - so which one am I ??? |
18th Aug, 2009 at 01:29:00am
Just ran out to the garage to make sure my engine had'nt been stolen and sold to you. lol Edited by Mr Joshua on 18th Aug, 2009. Own the day
18th Aug, 2009 at 08:03:58am
Lol, should think i have done a piston/ring as number 2 is way down on comp, will strip it later and have a look.
18th Aug, 2009 at 01:46:05pm
If the ring was letting loads of pressure blow by and the block doesnt have big breathers maybe it caused pressure on the turbo oil return? But that would have to be a lot of blow by.
18th Aug, 2009 at 02:52:00pm
Well heres the reason for the breathers blowing:
18th Aug, 2009 at 03:25:26pm
I dont think we need any more return pictures...
18th Aug, 2009 at 03:43:22pm
Bad luck.....
18th Aug, 2009 at 04:09:35pm
just No2 |
18th Aug, 2009 at 04:38:29pm
Proper job well done!
18th Aug, 2009 at 04:42:14pm
Nevermind that
18th Aug, 2009 at 06:34:36pm
Have you seen it then Nic?
18th Aug, 2009 at 06:38:40pm
oooof!
18th Aug, 2009 at 06:44:44pm
only the pics on tmf from mitp
18th Aug, 2009 at 06:57:29pm
Yeh its that one, didnt quite make it to the mini car park and santa pod due to the smoke!
18th Aug, 2009 at 09:52:40pm
what boost was you running ?
19th Aug, 2009 at 07:52:44am
it was running 15psi,
Edited by retroracer1380 on 19th Aug, 2009. |
19th Aug, 2009 at 11:02:24pm
biit high in my opinion, 24 seems safe to me On 28th Aug, 2011 Kean said:
20th Aug, 2009 at 02:06:37am
On 19th Aug, 2009 retroracer1380 said:
it was running 15psi, Its on a dizzy had it set to max advance of 27deg, just been doing some searching and now a bit worried that was a bit high? Any thoughts? Too high!! my Megas went at about that... Inspect your other pistons.. odds are they have some cracks as well.. my advice is to think about Accralite forged.. fit and forget. Terry website:- http://www.terryhunt.co.uk
20th Aug, 2009 at 03:41:09am
It seems to me that you can just be unlucky with pistons. I have been running 12-15 psi on MG Midget pistons, with an accidental burst or two at 20 psi + and I run 28 degrees max.They are still performing,but are due for replacement this autumn as my engine too is now blowing a bit of oil and smoke about.I guess its a combination of things, including AFR,timing,boost and a heavy right foot all coming together at the wrong time, or too often. |
![]() 1733 Posts Member #: 1910 Post Whore Wilts |
20th Aug, 2009 at 08:24:09am
On 18th Aug, 2009 retroracer1380 said:
Yeh its that one, didnt quite make it to the mini car park and santa pod due to the smoke! They were Omega cast 11cc There some of it on the miniworld website too from the weekend: http://www.miniworld.co.uk/gallery/v/photo...G_8949.jpg.html Eh? didn't this used to be 85/86 model on a C, or is that a private plate? Sorry for the thread hi-jack. On 15th Jul, 2009 fastcarl said:
the pissed up clown stood back up, did a twirl and left bollock naked, |
31st Aug, 2009 at 06:30:32pm
Well i built my new motor, and fitted the same turbo and theres no smoke at idle so sumpnut must have been right where the blown ringland was pressurising through the oil return on the turbo and blowing oil past the seals into the exhaust. Thought might be handy if anyone has the same prob! |
