Home > Help Needed / General Tech Chat > changing main bearing with gearset still in place?
welshdan
Member #: 1111
s wales
hi, picked a gearbox up but the main bearing on the main shaft on the drop gear end of the box has a broken race.
is it possible to remove this with the circlip pliers and puller and change the end bearing with the gearset still in place? many thanks
you'll need to take the laygear out, and pull the firts motion shaft, but the mainshaft can stay in place.
Mini13, I think he is talking about the first motion shaft bearing, so yes you can just pull the first motion shaft, but you will still need to lock the box to remove the input gear retaining nut
Or
is he talking about the first motion shaft support bearing (nose bearing)???....
Edited by Sprocket on 17th Aug, 2009.
good point, for got about locking the gearset, sooo the right hand plate on the diff housing needs to come off to lock the box up.
but yes if its the one right on the end that can just be pulled off.
welshdan
Member #: 1111
s wales
sorry for the confusion there. its the one next to the drop gear, and is in the end of the gearbox casing.
am pretty sure i can get it out without removing the gearst. cheers for the replys
Drop gear? you mean the input gear?
This is the sequence of drive, excluding fourth and reverse, for all the pedantics out there *tongue*
primary gear
idler gear
input gear
first motion shaft
second motion shaft (laygear)
third motion shaft (main shaft)
pinion
crownwheel (differential)
So the bearing sandwiched between the input gear and the first motion shaft, BIG circlip and it sits in the gear case itself?
Yes, you can pull the first motion shaft and change the bearing, but you WILL have to lock the box in some fashion to get the nut off.
