Home > For Sale > 1293 turbo engine
holmesgraham
Member #: 2556
Southport, Merseyside
for sale.
The engine spec is,
+20 thou overbore to 1293 (done by minisport)
t3 camshaft and hardened followers (MED)
skimmed flywheel (by MED)
comp clutch (MED)
highlift rockers 1.5-1 (MED)
high capacity oil pump (MED)
Garett t3 turbo
hardened and balanced crankshaft (by minisport)
genuine metro turbo head with double valve springs and sodium exhaust valves
metro turbo inlet manifold
metro turbo exhaust manifold and downpipe
metro turbo distributor
4 core radiator
Spi fuel tank. you can even have the 10mm lines if you like.
standard 4 speed gearbox
engine has been running but has only covered 15 miles. it has only been ran on 4 psi of boost
has been sat for 6 months, was running fine before i left it but now has a misfire. i'm sure this is very easily solved.
the reason i am selling the engine is because i work away from home and never get chance to use the car. i would rather see the engine put to some use rather than sitting in my garage.
Any offers please email me on
holmesgraham@hotmail.co.uk
thanks
Graham
PLease state a price as per for sale rules.
holmesgraham
Member #: 2556
i dont really know what its worth to be honest?? £1500? offers more than welcome
minilakey
Member #: 6780
lymington hampshire
r u in arush to get rid of your engine cos i should be able to get the money up in a couple of months ????????
holmesgraham
Member #: 2556
no rush at all. just get in touch when you have it.
minilakey
Member #: 6780
lymington hampshire
sweeeet:)
minilakey
Member #: 6780
lymington hampshire
bad times......... ive managed to lose my job!!! still on the case to get hold of some money have u still got the the engine for sale????????
