| Home > Help Needed / General Tech Chat > Towing eyes with a removable front? | |||||||
![]() 667 Posts Member #: 5232 Post Whore basingstoke |
18th Aug, 2009 at 09:15:34pm
Hi guys,
Mr. Prawn, the friendly Crustacean- slowly making steps towards forced induction. |
444 Posts Member #: 2885 Senior Member |
18th Aug, 2009 at 10:06:50pm
I have something more like this: (but sturdier)
18th Aug, 2009 at 10:34:30pm
mines just a small eyebolt each side of the front subby. works well and is neat. |
18th Aug, 2009 at 10:34:45pm
same on the back as well |
18th Aug, 2009 at 11:43:42pm
I have a exhaust hanger on mine bolted through the subframe. It's a bit bent but works a treat! |
19th Aug, 2009 at 07:39:55am
Cheers guys, Iain, do you mean like a small harness eye bolt? are yours mounted into the bottom of the subby facing downwards? What I'm really after is a way of securing a towing eye that sits just below the front valance really. I think the eye bolt idea sounds neat. Edited by Prawn on 19th Aug, 2009. Mr. Prawn, the friendly Crustacean- slowly making steps towards forced induction. |
19th Aug, 2009 at 09:15:58am
yes, well these are lifting eyebolts but the same thing. being lifting ones you can get them in all different sizes you see. think mine are about 1" in diameter so maybe something like M12 or M16 ones.
19th Aug, 2009 at 09:35:41am
awesome. that's exactly where I pictured them when you said it. Something around an m12 thread would be perfect. I might do the same on my rear beam to aid strapping the back end down (where do you normally strap with a rear beam!)
![]() 299 Posts Member #: 2814 Senior Member Mansfield - Notts |
21st Aug, 2009 at 10:07:25pm
http://www.merlinmotorsport.co.uk/p14090/S...oduct_info.html
21st Aug, 2009 at 10:13:47pm
I thought of those TB, but my issue is, I'm taking a solid tow bar with us in the Audi should I get any more major problems whilst out at the Ring. If it dies, I'd want to tow it back on the solid bar, meaning some form of solid towing eye is needed, rather than a strap. For trackday type use only, a strap would be perfect Mr. Prawn, the friendly Crustacean- slowly making steps towards forced induction. |
21st Aug, 2009 at 11:04:41pm
On 5th Sep, 2011 Vegard said:
