| Home > Beginners Tech > pistons | |||||||
11 Posts Member #: 6531 Member |
19th Aug, 2009 at 07:46:21pm
if i wear to fit a turbo to my standard 1275 mini could i just get the chambers of my head bored out instead of changing my pistons ?? |
![]() 1252 Posts Member #: 1656 Post Whore stoke-on-trent |
19th Aug, 2009 at 10:44:04pm
standard pistons dont take particularly well to boost...I'm sure this has been covered a few times before...worth a search I think On 23rd Oct, 2009 sim_ou_nao said:
eu gosto de mamas = i like boobs |
20th Aug, 2009 at 06:59:11pm
im using standard pistons on mine, will only be running 10psi.
Edited by welshdan on 20th Aug, 2009. |
20th Aug, 2009 at 07:27:57pm
On 20th Aug, 2009 welshdan said:
im using standard pistons on mine, will only be running 10psi. just to make sure i can get the turbo engine working with the mj etc, am also converting the car from spi. the engine with standard pistons wont be in there for long once i get things up and running have you seen the spi pistons, one hell of an oil groove, your a brave guy!!
i have just removed a set off my rods... Yes i moved to the darkside |
20th Aug, 2009 at 07:38:57pm
lol, the engine im using is an early metro one |
20th Aug, 2009 at 07:43:20pm
lol, the engine im using is an early metro one :) i couldnt tell you what pistons u have then i was very surprised with mine though after looking them over i didnt think twice about replacing them (my spi piston no 21963)
20th Aug, 2009 at 07:47:46pm
as i said i will be using the engine just to get things running. have been rebuilding the car from ground up. just ready to spray it so not too far off! once things are going then il be looking to build something a little more suited |
