Home > Beginners Tech > replacing core plugs on rebuild
welshdan
Member #: 1111
s wales
hi, im rebuilding an engine for my mpi daily drive at the moment.
just wondered what the benifits of changine the core plugs in the block were?
from what i understand they are only into the waterways, so any minuscule particles in there will only circulate the water system anyway?
aslo are the drilled out and then tapped back in with some sealant?
cheers
just put a screwdriver through them and pop them out. new ones i normally tap in dry but im sure some people use sealant.
Its pointless not doing them and when they're out you can clean the waterways better.
Oli
Member #: 1910
Wilts
Yeah, i tend to puncture them with a punch, and then hook them out. Then just tap the new ones in using a socket so it goes in square.
Worth doing if the engines being rebuilt.
Edited by Oli on 20th Aug, 2009.
welshdan
Member #: 1111
s wales
was going to just flush the waterways out with a hose pipe.
was worried that if messed with they are more likely to leak.
cheers for the fd by the way oli.
Jason G
Member #: 1459
En-suite user
Braintree, Essex
They are not expensive...worth doing. Another thing...I can't stand them painted!
On 19th Jan, 2010 wil_h said:
retroracer1380
Member #: 1972
Worcester
I just tap them in the corner with a punch, makes them spin round so you can get them out, then just clean up the block with a flap wheel or wire brush on a drill/die grinder before fitting the new ones
ditto, don't paint them:)
