| Home > Help Needed / General Tech Chat > main bearing rebuid query | |||||||
![]() 508 Posts Member #: 487 Post Whore westbury, wiltshire |
20th Aug, 2009 at 11:59:10pm
just got the main bearings and caps and crank installed to in the block to check that all rotats nice, i can turn the crank with one had and is smooth, how easy should it be to turn a crank eg with one hand or two fingers, bearings were supposedly measured and supplied for the block "Can I legally marry people now that I am ordained in the Church of the SubGenius?" aka i know jack sh"t
21st Aug, 2009 at 07:56:00am
One hand is OK. Two fingers is impossible with proper engine building lube is used. On 13th Jul, 2012 Ben H said:
21st Aug, 2009 at 09:06:38am
Get some plastiguage on it to check clearences On 7th Oct, 2010 5haneJ said:
21st Aug, 2009 at 04:19:32pm
just took it to local engine builder/machinest and they said it was too tight which i thought, there going to have a look for me and sort it out, what gribes me is that this was all ment to be taken care of when the block was done and the bearings supplied by the company that took care of the machining aaaaaaaaaahhhhhhhh "Can I legally marry people now that I am ordained in the Church of the SubGenius?" aka i know jack sh"t
