| Home > Help Needed / General Tech Chat > Wiring help | |||||||
![]() 2102 Posts Member #: 432 Post Whore Swindon |
23rd Aug, 2009 at 11:54:05am
I'm connecting all the engine (1275 n/a) up at the minute, and i seem to have some spare wires......
23rd Aug, 2009 at 12:37:49pm
Are these (first four lines) near the dizzy ???
Edited by Rod S on 23rd Aug, 2009. Schrödinger's cat - so which one am I ??? |
23rd Aug, 2009 at 05:04:25pm
yes they are near the dizzy.
23rd Aug, 2009 at 05:24:48pm
Yes, the two wires from the electronic dizzy go to the coil - if it's the correct short "loom" from the Metro they can only go on the coil one way (one connector is male, the other female) BUT, you must use the correct coil to match the electronic dizzy.
23rd Aug, 2009 at 07:05:13pm
the loom is the original 1986 lom so it would have been ballast ignition, i can't see a plain white wire..... |
23rd Aug, 2009 at 07:57:16pm
Early to mid eighties when they changed to ballast ignition (the pink or pink/white wire is the giveaway) they actually used the original loom and put the ballast feed and feedback wire to the solenoid in a seperate small loom (actually just a small sleeve) and left the original white 12V ignition wire taped up into the loom at the front to hide it.
